2004 G35 with OEM Rays
Old Jan 28, 2013 | 03:43 PM
hockeyadc's Avatar
I've spent the past hour searching and can't find my exact setup.
I'm under the impression that 225/40/19 in front and 255/40/19 in rear will work fine, but I wasn't sure if that was on a 2004 G35, since the stock wheels are 18.
Will this throw my VDC off? Currently I have the 225/40/19 up front and 245/40/19 in rear.
Thanks in advance.
Old Jan 28, 2013 | 03:45 PM
JaE35's Avatar
Moderator
G35 Sedan
255/40 is a big tire...do 245/40 in the rear as paired with a 225/40 up front are stock sizes
Old Jan 28, 2013 | 03:46 PM
hockeyadc's Avatar
yeah I kinda want a bigger/meatier tire. From what I can find it will fit fine, but I just want to make sure since its a 2004 it wont throw the VDC off
Old Jan 28, 2013 | 03:51 PM
JaE35's Avatar
Moderator
G35 Sedan
225/40 is a really little tire to be paired with a 255/40...i run 235/35 F and 255/35 rear...i'd up the size to a 235/40 up front or a 245/40 up front to go with the 255 then
Old Jan 28, 2013 | 03:54 PM
hockeyadc's Avatar
Little as in looks? I figured since its just the width I'm changing the VDC would be fine. but yes I do have to figure out if it will look stupid.
Just wanted to figure out the VDC issue first lol
Old Jan 28, 2013 | 04:11 PM
Songle6MT's Avatar
When you changed the width of the tire you are actually changing the sidewall height as well.
Old Jan 28, 2013 | 04:18 PM
hockeyadc's Avatar
Here's where it is confusing. According to this thread:
https://g35driver.com/forums/wheels-...0-19-rear.html
It will work(not sure if that's a 2004 or not or if it matters)
But when I use the tire size configurator, it's a difference of 3.5%. Reason I'm using these sizes for the front is because I got a pretty good deal on some tires.
Old Jan 28, 2013 | 04:34 PM
JaE35's Avatar
Moderator
G35 Sedan
it will look stupid even if it doesn't upset VDC..huge rake, is that straight forward enough? lol
Old Jan 28, 2013 | 08:19 PM
hockeyadc's Avatar
Fine you convinced me lol. went with what I have now. 225/40/19 and 245/40/19.
Old Jan 28, 2013 | 08:57 PM
JaE35's Avatar
Moderator
G35 Sedan
Great job, those sizes will look good together...those are OEM specs and will not throw off your speedometer
vmcarbuyer
Oct 12, 2019 12:42 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
brycealbr
Aug 11, 2015 11:47 AM
