need help with lowering.
Old Jan 26, 2005 | 03:19 AM
InDiGo's Avatar
recently got my 19" volk sf-challenge installed and i want to drop the car a lil bit...most people told me to go with eibach pro-kit...any suggestions?
Old Jan 26, 2005 | 07:33 AM
g35audioman's Avatar
I know you probably don't want to hear this, but do a search. There must be hundreds of threads on suspension. You will learn everything you want to on those threads.
Old Jan 26, 2005 | 12:22 PM
jdbinspired's Avatar
Too me... I think it depends on how you want the ride, some like the smooth feel, while others like the stiffness... it's the sway bars that would really make a difference...
Old Jan 26, 2005 | 12:46 PM
kenchan's Avatar
The Prokit is for people that want a good drop. You should look at H-Techs
or RSR springs for the G and finish off with swaybars.
Old Jan 26, 2005 | 01:06 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
... i want to drop the car a lil bit........any suggestions?
What does a little bit mean to you?
The littlest bit that I know of is OEM 350Z springs.
They are the same rate & will drop the coupe by 0.5"
Old Jan 26, 2005 | 01:30 PM
sen_jen's Avatar
Meatshake Enterprise
Tein S Tech, Eibach Pro-Kit, RSR titaniums, drop the car at a level. The spring rates vary and it's not as stiff as if you get full coil-overs. However, if you were to install coil-overs (e.g. Tein Flex/Cusco Zero2/HKS LS/RS), the recommended drop by the manufacturer will be just about the same as just drop springs. Meaning, they work best at the height recommended.
I'd suggest either of these springs listed. The drop aint crazy low, but just right. G35 coupes already hang quite low (underneath), and clearance sucks.
b2autodesigns
Suspension-Vendor
112
Feb 24, 2017 11:19 AM
sales@czp
Suspension-Vendor
Oct 10, 2014 12:22 PM
NuGen Auto.
Suspension-Vendor
49
Sep 8, 2014 12:44 PM
ukg35
2nd Gen (V36) Sedan
Jul 18, 2014 08:48 AM
Startbutton99
Archived Sales
14
Jul 16, 2008 05:20 PM
