2004 g35 coupe rim/tire size combo
Old Jun 3, 2013 | 03:08 PM
g-reminisce's Avatar
Hey guys i have aftermarket rims, first owner had 275 30 20 on the rear but I need to replace them . Would a 275 40 20 tire size fit the same rim and not rub against the car , what size would you recommend for 20 inch tires ?
Old Jun 3, 2013 | 03:43 PM
MicntaeG35's Avatar
Depends on how much clearance you had between the tire and body with the 275/30. But I'm pretty sure a 275/40 would fit no problem
Old Jun 3, 2013 | 06:18 PM
bchalks's Avatar
Keep in mind your speedo is going to be off with a taller tire
Old Jun 3, 2013 | 07:48 PM
Blue Dream's Avatar
I drove ttrank's car solo
OP you seem new to the G and that's cool, we've all been there. What you need to know about the tires is the rolling diameter F/R needs to be within 3% of each other to keep the VDC happy. So you'll need to know the size of your front tires first to determine what size rear tire/s will work.
There's a great wheel/tire calculator in this link. http://www.miata.net/garage/tirecalcold.html
So using it, if your front tires are say 245/35/20 the diameter is 26.8". A 275/40/20 is 28.7" which is 1.9" or 6.6% different which will freak out your VDC and send your car into limp mode. A 275/35/20 would be 2.9% different which is pushing the 3% target so if you want to keep 275 as your width the 30 series is your best bet. If you want more sidewall a 265/35/20 would be .3" taller and the diameter difference would only be 1.9%
Hope this helps and doesn't confuse the hell out of you.
Old Jun 3, 2013 | 08:58 PM
gary c's Avatar
What Tim just told you was No you can't run 40 series tires with your 20" rims, stay with the 30 series....Gary
Old Jun 3, 2013 | 10:12 PM
sjsharky4's Avatar
Depends on if your lowered. I was lowered an inch and a half with 19's and I rubbed with a 35 sidewall.
Old Jun 28, 2013 | 02:52 PM
eddieg323's Avatar
Hi Gary, I'm new here had a question, can I run 275/35/20 rear, 245/35/20 front? I really want 35 up front for a smoother ride, I will be Rollin fenders, thanks
Old Nov 17, 2013 | 04:24 AM
paolojericho11's Avatar
Hi i'm new here too i just bought a 20x8.5 inch rims whats the best tire size on the front and rear, one of the tire guy i saw said i can roll a 255/40 in the front but im not sure if his right please help me here thanks
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
igking
Jul 19, 2015 01:12 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
