Ok to mismatch tires?
I would only run those different sizes in an emergency, like on the way to your local tire store! Using 245s on the front is normal just not with a 225 on the other side. No, not recommended!
Gary
Gary
Both rears are also 245s but what would happen if the 2 front is mismatched? It's the same height but different width what's wrong with that
225/40/19 and 245/45/19 aren't even close to being the same height- there is an inch and a half difference in diameter and the sidewall is an inch off.
Front to back I understand provided the rears are taller by a margin but side to side should be the same profile.
Even if the width is the only difference, they aren't the same diameter. Stop playing cheap with your car and get it fixed, or else get rid of this car for something you can actually afford.
our traction system will freak the heck out if one side spins different than the other, it can tolerate difference between front and rear.
So if you need to run different sizes (which we all do) difference should be only between front and rear not left and right.
One axle should have same size tires on it, no matter if it's emergency or not.
