Sedan 19" Rims
Old Feb 1, 2005 | 02:31 PM
leatherSOUL's Avatar
Sedan 19" Rims
From what I've been reading, 19x8.5 +38 front and 19x9.5 +45 rear on a sedan seems to be the consensus.
I'm looking at a set of rims that come in a 19x8.5 +37 front and 19x9.5 +43 or +37 rear. Would this work with TEIN H-Tech springs?
Thanks for your help. Any pictures of staggered 19" sedans would be great too!
Old Feb 1, 2005 | 04:04 PM
Gsedan35's Avatar
You can run 8.5" wide with a 37mm offset as long as you stick with a 245mm tire in the front, certainly do not go narrower then that since your buying a new setup anyhow. In the rear since a 275 wide tire is really close to the fender lip with a 45mm offset on a 9.5" wide rim, as long as you limit your rear tire choice to a 265mm tire, you'll be ok. That or know you will be rolling the rear fenders. Or you could pick a different rim combo to get the better offsets.
Old Feb 1, 2005 | 11:48 PM
g35_6gear's Avatar
I agree on the +37 on a 8.5 front. I ran a 275 on a 9.5 rear with a +55 offset and it looked stock....except from behind
Old Feb 2, 2005 | 11:44 PM
hksjza70's Avatar
I ran a 275-30/19 falken st-115 on a 19x9.5 +42 rear with no problems (car was lowered) - size kind of matters - but you can still run a 275 as long as you stick with a round sidewalled tire (i.e. falken st-115), the really square sidewalls - like yok avs sport or bfg's will probably look like they're sticking out
Old Feb 14, 2005 | 05:11 PM
AmistadUSA's Avatar
again, it depends on the wheel brand and wheel type you choose
Old Feb 14, 2005 | 09:46 PM
G35Lin's Avatar
Multi-Spoked Mod
yea it should fit/// leathersoul.....
At least for volks they do..
Amistads like what i have is another issue! No pics yet. If you want to see.. Come to HIN LA to see!
Ed
Old Feb 14, 2005 | 10:26 PM
ajayjuneja's Avatar
Buy g35lin's rims, leathersoul!!!
Old Feb 14, 2005 | 10:31 PM
G35Lin's Avatar
Multi-Spoked Mod
oh yea... My rims are up for sale:
see link: https://g35driver.com/forums/showthread.php?t=44152
Ed Lin
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
