Vossen wheels suck!
Old Aug 4, 2013 | 08:10 AM
ivey_usmc's Avatar
Originally Posted by WhosUrBuddiee
Did your shop install hubcentric rings?
Yes there are rings
Old Aug 5, 2013 | 10:14 PM
JKL1031's Avatar
They seem to be taking off well as a company.
Old Aug 6, 2013 | 01:35 AM
guitarrocker98's Avatar
They are taking off well, because they make cheaper wheels. Seriously. Around 2k cheaper than most other new wheels. Vossens are just around 2k. Are a 1 piece cast, and suck at doing that. Works, volks, iss forged, rays, hre wheels, etc. are 2 or 3 piece forged. Those are much better than cast wheels. Also those companies back up their wheels with mass testing. Done and done.
Old Aug 6, 2013 | 09:30 AM
ivey_usmc's Avatar
Yea this was a real learning expierence for me! Sucks it was $2k lesson
Old Aug 6, 2013 | 09:39 AM
nogoodname's Avatar
That's pretty shitty. 2-3K for shaky wheels. I thought they had a warranty for defective wheels? Overpriced at its finest.
Old Aug 6, 2013 | 10:56 AM
MJION's Avatar
I've always been a fan of Forgestar for a quality and resonably priced - one piece forged wheel. Sets can be had for under $2K....
http://www.forgestar.com/v2/testdata.php
Old Aug 6, 2013 | 02:14 PM
Yes forgestar wheels Are fairly well built. I trust them. For one piece forged I trust them, and enkei wheels and a handful of other brands. Don't trust many brands with my shoes. They keep you on the road. Don't skimp on them. Don't really skimp on tires or flipping lug nuts or studs. I can't count how many times people cheap out on wheels studs, and something goes wrong just to save 30 bucks. Certain parts I don't cheap out on.
Old Aug 6, 2013 | 04:28 PM
TIAN's Avatar
Hold The Line
I've had SSRs, Racing Hart, Volk before and now Vossens for 3 years. I've had 0 problems with any of them. Good luck OP
Old Aug 6, 2013 | 06:21 PM
JKL1031's Avatar
is it just one wheel? u have 8 wheels correct? maybe u cud find the correct combo?
Their active here if your ballsy enough to get back in their face. http://www.myg37.com/forums/wheels-a...st-up-145.html
Old Aug 6, 2013 | 07:22 PM
ItsA..Gthing's Avatar
8 wheels?
Old Aug 6, 2013 | 07:37 PM
Deezflip's Avatar
what kind of tires are you running? it could be the tires where cheap tires can bubble, belt shift, warp, etc.
Old Aug 6, 2013 | 08:44 PM
TIAN's Avatar
Hold The Line
Originally Posted by ItsA..Gthing
8 wheels?
Sounds like Vossen let him keep the first set and sent another set.
Old Aug 6, 2013 | 09:34 PM
JKL1031's Avatar
Yep. Two possibilities for each corner. But then he said he kept the second set.
Old Aug 7, 2013 | 12:44 PM
WhosUrBuddiee's Avatar
Majority of Work wheels are cast. Just because they cost as much as forged wheels, doesn't always mean they are.
Old Aug 7, 2013 | 12:54 PM
  #30
But 8 wheels and still problems... I tend to think the issue is with the installer and not manufacturer.
Was your installer able to balance them?
-If YES. Then wheels are fine, you have somethign wrong with your car. Worn out ball joints, shocks, bearings, bushings and tie rods can introduce vibrations that will feel like an out of balance condition.
-If NO. Then you never should have installed unbalanced wheels on your car in the first place. Take the tires off and perform runout tests. It will tell you if the problem is the rim or the tire.
General rule of thumb is that if you feel vibrations under 40mph, then you have a runout problem. If you feel vibrations over 40mph, then they are not balanced properly. If you feel vibrations at all speeds, then it is a mechanical issue.
Sounds like it is most likely you have a mechanical issue or incompetence with your installer.
