20 inch wheel question
Old Feb 2, 2014 | 12:51 PM
Mack813's Avatar
hello guys...
i just bought these rims and tires off a guy and they are a set of 20s with tire specs 245/30ZR20. i think all the tires are the same spec and size the rims are 20x9 as well
i drive a 2007 g35 journey sedan RWD i was wondering if i would be able to just throw the wheels on the car and everything will work fine? the rims do fit on the car but i haven't put all them on yet and test drove it yet.
am i missing something else? do i need wheel spacers? and could i put lowering springs on it with these 20s?
Old Feb 2, 2014 | 12:58 PM
Mack813's Avatar
also what will i have to do with the tpms sensor?
Old Feb 3, 2014 | 12:05 AM
NJzFinestG's Avatar
wut are the offsets? i wouldve went with a staggered setup for RWD. if it has TPMS on the wheels then u have to get it reprogramed for ur car it they arent already.
depending on how much camber will determine if u need spacers.
Old Feb 3, 2014 | 12:09 AM
Mack813's Avatar
How do I find the offset? Online it's saying RWD?.... I put one wheel on so far and it spins with no rubbing do I still need the spacers?
Old Feb 9, 2014 | 04:57 PM
NJzFinestG's Avatar
what kinda of wheels are they? usually inside of the wheel should be stamped. would say 20x9 (ex: +45) or whatever the offset is. what the wheel sit far inside the fender or poke out?
Old Feb 9, 2014 | 05:08 PM
Mack813's Avatar
I found a stamp that said ET10 ... Doesn't sound right... But a site I went on said the rims will poke out almost 2 inches than stock wheels.. And there might be fender rub?
Old Feb 11, 2014 | 02:21 PM
NJzFinestG's Avatar
yea ur gonna need to be low, get neg camber, and fender work for those to fit.. IMO
Old Feb 11, 2014 | 03:32 PM
Mack813's Avatar
How do I get negative camber?
Old Feb 17, 2014 | 11:18 PM
gary c's Avatar
You didn't post the offset of your new wheels so giving you a firm answer is going to be tough! You could try installing the wheels making sure they clear inside the lip out back, up front make very sure the inside of the rim isn't close to your suspension. You can without reprogramming them have a tire shop install the TPS on your new rims once you're sure they'll fit. I've had mine in 4 different sets of wheels without issues...Gary
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
realtalk21
Jul 20, 2015 09:07 AM
Soumilg
Jul 18, 2015 12:33 PM
EasySausage
Jul 14, 2015 11:17 PM
