TPMS with valve stems supplied with aftermarket wheels
Old Mar 12, 2014 | 05:20 AM
scottvt's Avatar
I got a new set of wheels, and tires, and am itching to get these mounted and on the car. I am unsure of what to do for the TPMS. I am a TPMS noob, and tried to search, but didnt find much at all. The valve stem holes on the new wheels are behind the face of the wheel, and so they came with extended valve stems that are bent at a 90 degree angle. They look good and will make pressure adjustments easier. Is there a sensor I can use on these valve stems that will work? Or are we limited to the straight valve stems with built is sensors? Thanks for any help, and sorry if this has been covered!
Old Mar 12, 2014 | 07:40 AM
Urbanengineer's Avatar
http://www.ebay.com/itm/231167286490...84.m1423.l2648
This part number from the sale is stock. I'm not certain what will definitely work and what will definitely not work, but it seems the almost straight ones from Nissan seem to be what the aftermarket companies sell too.
Old Mar 12, 2014 | 08:48 PM
scottvt's Avatar
You can't replace the valve stems on these can you? I was asking if there is a TPMS sensor that I could fit onto the valve stems that came with my wheels.
Old Mar 13, 2014 | 07:59 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
I haven't found an alternate valve that bends like it sounds you need and also works with the sensor.
Old Mar 14, 2014 | 03:44 AM
scottvt's Avatar
So what is the popular choice with aftermarket wheels? TPMS? Or deal with the light?
Old Mar 14, 2014 | 10:33 AM
Blue Dream's Avatar
I drove ttrank's car solo
Deal with the light unfortunately.
Old Mar 14, 2014 | 04:17 PM
JKL1031's Avatar
Im confused on why the factory ones wont work?
Old Mar 14, 2014 | 04:21 PM
PLATINUM SPONSOR
The dip in the wheel near it's lip may not allow for a sensor to sit properly and seal against the wheel. Unfortunately not all wheels can accommodate sensors due to their design, so adapters or the like are needed.
Old Mar 14, 2014 | 10:44 PM
scottvt's Avatar
I am not sure if the factory would have worked or not. I simply wanted to use the valve stems that came with the aftermarket wheels and wanted to know if sensor were able to be attached to different stems.
Either way, I got the tires mounted on the wheels today so I will be ignoring the light.
Old Mar 20, 2014 | 04:25 PM
derek619's Avatar
just got a set of volks with the rear valve stems the way you have described. take a look at this thread, this should solve you tpms mounting isue.
https://g35driver.com/forums/brakes-...-work-etc.html
Old Mar 20, 2014 | 05:21 PM
JKL1031's Avatar
So u have to do this if ur valve stem isn't on the face of the rim, but within the barrel of the rim?
Old Mar 20, 2014 | 05:47 PM
derek619's Avatar
I plan/would use this bracket rather than mounting the tmps sensor directly to the wheel barrel for convenience. say you had to inflate your tires or deflate them a bit, you would have to either remove or reach behind the wheel to get to the valve stem.
Old May 13, 2014 | 07:02 PM
derek619's Avatar
For anyone who stumbles on this thread looking for a solution, these guys have them. https://g35driver.com/forums/wheels-...et-wheels.html
Old Apr 18, 2022 | 02:48 PM
Southy1021's Avatar
I am not sure if they are still in business but can't get a reply for these adapters. Has anyone found another option like these that they have used that work?
Thanks, Donald
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
BlackGee35
Jul 23, 2015 01:36 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
