Help with wheel spacer size
Old May 15, 2022 | 10:11 PM
bdarley's Avatar
Infiniti G35
I’ve recently bought a 2006 g35 coupe. wondering what size spacers i’d need for a flush fitment on OEM 19” wheels? for both the front and rear sizes if i may ask, thank you in advance!!!
Old May 16, 2022 | 02:26 AM
Scorpi0's Avatar
I think a 1” spacer on the rears would
make it flush. Not sure about the fromts though.
Old May 16, 2022 | 12:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Keep in mind you need to roll all the fenders if you're going flush, You can literally just lay a straight edge (cut a piece of wood to length) across the front of the tire then use a tape measure to measure exactly how much spacer you need.
I'm 15mm front and 25mm rear. Both are rolled, anything more than that will rub over bumps and parking lot entrances with a 1/2" drop from the revised 350Z springs.
Previously I was 25mm front and 35mm rear on S-tune springs, that rubbed like crazy... plus it flung a LOT more road splatter on the side of the car, my current 15/25 doesn't make nearly the mess.
Here's the current setup.
Old May 17, 2022 | 11:28 AM
G2B35AGN's Avatar
I have 20 front and 25 rear on my 06 coupe. Stock height, no issues with front fender. Also have the Brembo swap from 03-04 coupe. Very happy with the look. Car is filthy with spring droppings. Ashamed to take a pic, but I'll swallow pride and see if I can add one in a bit.
Old May 17, 2022 | 11:31 AM
G2B35AGN's Avatar
Nice plate!
Old May 17, 2022 | 07:52 PM
G2B35AGN's Avatar
Here's some pics.
Attached Thumbnails Help with wheel spacer size-img_2569.jpeg   Help with wheel spacer size-img_2570.jpeg   Help with wheel spacer size-img_2571.jpeg   Help with wheel spacer size-img_2572.jpeg
Old May 18, 2022 | 12:44 AM
Scorpi0's Avatar
G2B, what your screen name mean?
Old May 18, 2022 | 11:03 AM
G2B35AGN's Avatar
I'm a Medicare-qualified citizen. I got me a G35 as a post-midlife crisis fun mobile. Gee... to be 35 again....
Old May 18, 2022 | 11:22 PM
Scorpi0's Avatar
Ohh ok. Nice haha 👍
Jhambor
Jan 13, 2016 05:17 PM
vivema
Mar 13, 2013 11:35 PM
rob g35
Jan 7, 2010 09:15 AM
fiable1931
Apr 24, 2008 05:00 PM
eledin
Jan 14, 2008 07:17 PM
