My first nice car..what tires do you guys recommend?
You'll find that tires have different wear specifications, traction specification, speed ratings, etc.
Really up to you to research what suits your needs.
Ok if you are inclined to take a step up in size you can get a 235/35/19 nitto nt555 for much cheaper!!!! Just and example..
ALL under 200 bucks..
Nitto 555
http://www.discounttiredirect.com/di...5&rd=19&cs=235
nittto invo
hankook ventus
If you are worried about your speedo then go to 1010tires.com and they have a tire calculator and then you see if the tire you chose if a perfect match or will it be way off and by how much..
Nitto 555
nittto invo
hankook ventus
Nitto 555
Nitto 555
Check tiredirect on ebay, maybe there sale is still going on.
Ok if you are inclined to take a step up in size you can get a 235/35/19 nitto nt555 for much cheaper!!!! Just and example.. ALL under 200 bucks.. Nitto 555 http://www.discounttiredirect.com/di...5&rd=19&cs=235 nittto invo http://www.discounttiredirect.com/di...5&rd=19&cs=235 hankook ventus http://www.discounttiredirect.com/di...5&rd=19&cs=235 If you are worried about your speedo then go to 1010tires.com and they have a tire calculator and then you see if the tire you chose if a perfect match or will it be way off and by how much..
Nitto is a significantly lover class tire compared to Toyo, Yokohama and Hankook
Here is a comparison done by Powercar comparing Vredestein to quite established brands of tires
It really is all preference. What are you looking for in your tire? Tread life? Reduced road noise? For me, I love Michelin PS2s, but they're too expensive and aesthetically the tread is ugly lol. Toyo T1Rs are solid, but also expensive. I'm a Hankook v12 kinda guy now. They're quiet, grippy, have decent tread life, and look great! I didn't like Kumho SPT or Falken FK452 because of the road noise. I've had a variety of wheels and tires but since I swap wheels frequently, I can't give a proper review on the other brands.
Sedan it's w/e. Front to back is fine but only on non-directional can you follow normal rotating guidelines.
