Tein Basic Dampers Coilover Setup - G35 Coupe
Old May 6, 2003 | 08:58 AM
djgcue's Avatar
I just finished test fitting the Tein basic dampers suspension kit and I highly recommend this kit when and if it is released. The ride is comfortable but tight while cornering. It also lowers the G35 coupe a little over 2.5 inches in the rear and the skies the limit for the front. I've lowered my car to a half finger all around which is about .75 inches more in the front and 1 inch more in the back vs. the Eibach Pro Kit springs. I have 20 inch wheels and there is no rubbing whatsoever. I will hopefully have new pictures by this weekend. However, my car is "riced" out (stupidest term I've ever heard) with manufacturer decals, since this car was used for a car show this past weekend so I'm a little skeptical of putting pictures up since many of you G35ers seem not to totally understand the aftermarket industry in terms of the required promotional circumstances.
6MT; Desert Platinum; Nav; premium; performance
Old May 6, 2003 | 10:07 AM
rajc007's Avatar
Re: Tein Basic Dampers Coilover Setup - G35 Coupe
<hr></blockquote>
Screw 'em, I really want to see a G35 that has been dropped more than the eibachs give you.
Old May 6, 2003 | 11:37 AM
Nismoboy's Avatar
i talked to TEIN the other day and they said that the 350Z Flex kit fits and rides fine, which also means you can use the EDFC with it...so is the Basic kit a whole new setup??? more aggressive?? or more aimed towards comfort? just curious as to why they haven't mentioned this on there webpage
John H.
Current: 2001 Infiniti G20t
Ordered: 2003 Infiniti G35 Coupe - ETA: May '03
Old May 6, 2003 | 11:55 AM
djgcue's Avatar
This is a prototype set-up Tein used on my car. Its different from the Flex set-up in that it does not have the 16 level adjustment and isn't compitable with the EDFC. As to when they will have information regarding the setup or when its going to be released, I'm not sure.
Old May 12, 2003 | 11:00 PM
bzabodyn's Avatar
I just checked out the newest pic you have posted under the "Rides" section and it kicks ***! Please post more pics of the current setup from different angles if at all possible - Your car looks simply amazing...decal or not! (lol)
Old May 13, 2003 | 07:49 AM
Carlos3186's Avatar
it looks nice but you say it lowers the back by 2.5 inches with 18s isent taht going to be way to much. Also some one said the 350 kit works. Do you think that this is the best road to go or should i just go with the eibach prokit
Old May 13, 2003 | 09:20 PM
Gsedan35's Avatar
These Teins have matched dampers (struts) with them. Unless you found upgraded struts to match the prokits in place of your stock struts, the Tien's will be superior, for a price of course. But then again, Eibach doesn't want you to know it takes more then just springs to get your suspension right.
It should really be understood that all the coilovers you'll look at are engineered with matching dampers. And it's a safe bet they they will all be stiffer (some more than others) then any lowering spring. Problem is, no one offers a aftermarket strut to go with stiffer lowering springs. Thank god Koni sports come out this fall.
Old May 14, 2003 | 02:52 AM
DallyCurtis's Avatar
Dude ... Djcue has 20s on there...and no .. 2.5 inches will not be too much, for the 20s let alone the 18s ...
Dj.... dude .. you car looks wicked ... you have ANY idea of what this kit ...( I know its prototyped) will cost?
and do they want a fully loaded black 6speed up in Toronto to prototype for shows as well?
(P.S as you can tell by the picture ... (YOU GOT EXACTLY WHAT I WANT)
later bros
Old May 22, 2003 | 08:18 AM
gumpdriver's Avatar
Montgomery's Finest
your car is for you........Don't worry about what everone else says..
Old May 22, 2003 | 11:24 AM
pestilence's Avatar
djgcue: a show this past weekend?? do you live in so cal?
if so -- the online show off thing?? if so -- were you the one in the carribian blue g35 coupe?
if so -- i was the guy with the dropped g35 silver sedan...
Old May 24, 2003 | 08:25 PM
Hey man... I was just wondering is there any word on if they wanna prototype my ride up here in Toronto ????
ehhhhhhhhhhh???
later bro..
thats not mine in the pic I posted ... I photoshopped it up abit from this other fella
either way ... I have a black black fully loaded 6speed May 03 production ... with armrest ... no mudguards.. exactly the way I wanted it.
later man... eh PM me.
Hasanbaloch
Feb 29, 2024 08:45 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Chattzx
Jul 17, 2015 11:23 AM
mjfenix
Jul 14, 2015 10:37 PM
