Random tire wear question
Old Jun 11, 2014 | 09:25 AM
DaD_e671's Avatar
So about 1 1/2 ago I was told my right rear wheel bearing need to be replaced which I did and just a few months ago this mechanic shop told me i needed to repace it again. Would thiscause my right rear tire to wear out so quick? I just put a new tire on around the same time I replaced the bearing. The left side is still good, so I'm lost...
Old Jun 11, 2014 | 09:34 AM
Mustang5L5's Avatar
It's possible. Depends on how the bearing failed and if there was movement in the hub and if it caused the alignment to change. For me personally, i had 3 bearings fail, and not one caused any tire wear issues.
I'd recommend getting an alignment after the bearing is replaced to check this
Old Jun 11, 2014 | 09:41 AM
DaD_e671's Avatar
That also is strange because I just got the alignment done after new tires installed and camber kit installed, and the wear is right down the center it did that to the last tire I had on.
Old Jun 11, 2014 | 11:23 AM
Blue Dream's Avatar
I drove ttrank's car solo
If the wear is not on the sides but in the center your tire was most probably overinflated.
Old Jun 11, 2014 | 03:20 PM
Mustang5L5's Avatar
What he said. Wear down the center usually indicated overinflated tires.
What pressure are you running and what tire size (if not OEM)
Old Jun 13, 2014 | 04:36 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Post some pix if you can. They will help better ID the issue.
Old Jun 13, 2014 | 05:42 PM
gary c's Avatar
You can't always trust tire installers or alignment mechanics to inflate your tires correctly plus the gauges can be incorrect. Tires wearing out the center indicates they had the maximum pressure in that tire, somewhere around 50 psi. Tires have written on their sidewalls max pressure and some dummy's think that's what you should run...not! Tire pressure in our tires s/b between 35 and 37 psi, nothing more or less! Your wheel bearing issue is another question? Make sure you're getting a real Nissan part not a part from the local auto parts store! They should last 100K+ miles, I've never replaced them on any of my Nissan's going back to '72.
Gary
hdmark
Apr 29, 2019 04:31 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
BlueBelleG35x
Jul 23, 2015 02:10 PM
