Running a square tire setup with staggered stock 19's
Old Jul 17, 2014 | 07:37 PM
LongJohn6284's Avatar
Will i run in to any issues running 245-40-19 on all 4 wheels with the backs being 8.5 and fronts being 8 inches respectively.
will it look funny at all...having a real difficult time finding definitive pics of someone running a square setup on stock 19s
any wisdom or hopefully pic of similar setup would be greatly appreciated
Thanks in advance
Old Jul 17, 2014 | 09:08 PM
Urbanengineer's Avatar
I'm pretty sure you've already been answered. It will likely rub in the front. That and it will look whack (taller tire in front). Do not recommend.
Old Jul 17, 2014 | 10:31 PM
Lartytiejdke3's Avatar
Doubt it'll rub if he's not lowered
Old Jul 17, 2014 | 11:53 PM
Jeff92se's Avatar
Red Card Crew
this is my 245 225 setup. On Z springs. Off hand, it "should" be okay
Old Jul 18, 2014 | 09:16 AM
LoSt180's Avatar
Should fit just fine, but why run a square setup when the factory specs are staggered? It's not like you'll be able to rotate the tires since the rear wheels are still wider. Well I guess you can have the tires removed and remounted in order to rotate, but that's an unnecessary expense IMO.
Old Jul 18, 2014 | 06:54 PM
Maybe you guys are right...the tire i wanted being only in 245-40 was my reason for wanting this setup. But might just look for another tire.
Old Jul 18, 2014 | 07:22 PM
gary c's Avatar
I've never liked the idea of running 225 in front and felt the 245/35 was more stable, with better control! With the 245s you won't have rubbing issues unless your offset is below the mid teens...OE wheels no sweat! Tires? Check out www.thetirerack.com
Gary
vitamin.v
Nov 7, 2019 06:10 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
itztwinki3
Jul 24, 2015 03:58 PM
realtalk21
Jul 20, 2015 09:07 AM
