another what will fit thread
Old Feb 14, 2005 | 11:09 PM
tkman00's Avatar
ok so i've finally decided on a set of staggered rimds for my sedan. i'm going 18x8.5/9.5 and +37/55(I think) for the offsets. i'm going to lower with a set of 05 coupe suspension. tirerack recommends 225/45-18 and 255/40-18 for s03s. can anyone recommend a set of toyo t1s that's close to the stock size of 215/55-17?
i've search and found intgr8r's post with a diameter of 235/40-18 265/35-18, but that's off by a whole inch. what's everyone's opinion on the bridgestone setup? i'm really just concerned with making sure that i find a setup where i don't curb the rims.
thx
Old Feb 15, 2005 | 12:27 PM
tkman00's Avatar
anyone?
Old Feb 15, 2005 | 12:44 PM
Gsedan35's Avatar
245/40-18
275/35-18
http://www.toyo.com/tires/tire_specsheet.cfm?id=2
245/45-18
275/40-18
http://www.tirerack.com/tires/Spec.j...omCompare1=yes
I would not put anything narrower then a 245 on the front.
Just to let you know you can run 255/40-18 in the front with your front rim spec, though it becomes more difficult to run a wider rear tire and keep the rolling diameters within reason front to rear.
Old Feb 15, 2005 | 01:14 PM
tkman00's Avatar
Gsedan35 - I knew you'd come thru, thx
cbax
Intake & Exhaust
11
Jul 15, 2023 12:43 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
reavensf
Sep 17, 2015 11:30 PM
BlackGee35
Jul 31, 2015 11:04 AM
