Mounting TPMS RIMS on a non TPMS car
Sep 4, 2014 | 03:15 PM
Okay... Ive searched and found a handful of results. But my question is fairly basic. Seems like a layup.... But I have a set of wheels. On the rear barrel, there is a hole where one would mount a TPMS... But the 03-04 models of G's didnt have TPMS.... There is a hole on the front for the valve stem then a hole in the back for the TPMS... So does anyone have any ideas on how to plug up the hole, or has anyone ran into this before? Thanks.
Reply 0
Sep 4, 2014 | 07:29 PM
So the wheel has dual valve stem holes? Sensors are a one piece unit with the sensor sitting in side the wheel and the valve stem as the external part (aka its antenna). Shouldn't be a place to mount two separate pieces. Posting a pic would help greatly to see exactly what you have.
Reply 0
Sep 4, 2014 | 07:39 PM
My 04 has tpms & only one valve stem hole. Also my old Work wheels came with dual valve stems, front of wheel & one on inner barrel. I did not use tpms with the works. Just mount another valve stem to inside barrel.
Reply 0
Sep 5, 2014 | 02:28 AM
I can get pics tomorrow. But what now is saying is correct. That's what is happening. What happened with his work wheels.
Reply 0
