Stillen Sway Settings w/ HKS Hipermax coilovers?
Old Feb 15, 2005 | 10:52 PM
skeleton_cru's Avatar
Sedan
OK, here’s the setup on my sedan:
HKS Hipermax LS coilovers, 19x8.5 wheels with Bridgestone S-03 tires. I will be installing Stillen sway bars sometime in March.
What would be your suggestion for the settings on the sways? I’m thinking soft in the front and medium in the rear. Any other suggestions and why? Thanks in advance.
Old Feb 15, 2005 | 10:57 PM
Gsedan35's Avatar
Agreed. Your HKS LS coilovers transfered a lot of roll stiffness to the front, upping the rear bar more then the front is especially prudent in your case. Ultimately, your goal is to get the car to behave like you like it, it's up to you to test and make changes if needed.
HKS LS G35 (Monotube construction, non adjustable dampners)
Spring rates 448/336
Stiffer then oem by F+43% R -1%
transfers 44% roll stiffness to the front
Old Feb 15, 2005 | 11:31 PM
Sedan
Thanks for the reply Gsedan35. Great info as always.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
