19x8.75 , 19x10.75 15offsets ??
Hey fellas, hope everyone had a fun and safe Halloween!
I was hoping I can get some advice, since my older brother went on his 18 month tour with the Army.
I finally have extra money for some rims and I wanted to know if I can install it without having to roll, pull or shave my fenders or having to play with the camber.
I have a g35 coupe with G Eibach Sportlines.I just bought some tires 235/35/19 fronts and 255/35/19 rears. The rim specs that I am look at are 19x8.75 15 offset and 19x10.75 15 offset. What do you fellas think?
Or any recommendations
I have been on rimtuck.com and tried searching the forums and I can not figure it out. If this setup has been asked before, I truly apologize. Any help would be greatly appreciated!
Fronts will fit fine, rears would require rolling the fender and definitely some camber play depending how you wanted the stance to look.
That said, I second the recommendation to pass on those cheap wheels. Save up a little more and wait for a quality set, preferribly one that's forged...you will be happy you did so.
Pass my support along to your brother, from one service member to another.
