>> Rim question
Old Aug 29, 2014 | 08:51 AM
tnmt_donkey's Avatar
Cool >> Rim question
I have the 06 coupe, with OEM 19".
I am planning getting a new set of rims and tires. The concern I have is I have the Akebono big brake kit all around, so the fitting a new set is a bit tricky.
The OEM 19" clears all four coners with no problem, no spacer needed.
10, 15 mm spacer is needed to use OEM M35 19".
5mm spacer is needed to use OEM M35 19" without the brake kit.
Any suggestion on width and offset? ( without spacer and fender rolling)
One set I am looking at right now is 19" XXR 530.
19x8.75 +15 front, 19x10.75 +15 rear.
Will this set fit?
If so, what tire size I should get?
Thanks for all the help !!
Old Aug 29, 2014 | 08:58 AM
Car is not lowered.
But might consider lower springs in near future.
Old Aug 29, 2014 | 09:57 AM
gary c's Avatar
Will this set fit? If so, what tire size I should get?
With almost a 11" wide rear rim and +15 offset running a decent size tire will require fender rolling and or pull. Tire size s/b at least 285/35 for the rim size...Gary
Old Aug 29, 2014 | 10:17 AM
What if I go for 19x8 and 19x9?
What offset am I looking at? again, the brake kit is the biggest concern.
Old Aug 29, 2014 | 10:52 AM
Lartytiejdke3's Avatar
Another removing of forged wheels for cheap cast wheels
Sad actually..
Old Aug 31, 2014 | 09:22 PM
thegreatkwijibo's Avatar
first,
and in answer to your question, what you need to worry about is the disc, not the offset. order your wheels with the highest disc offered, and you'll be able to clear the brakes.
Old Aug 31, 2014 | 10:39 PM
Gman56's Avatar
Check out tire rack. They are a sponsor here. They will take care of you!
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
