Need some help with my set up
Old Dec 30, 2014 | 04:33 PM
itztwinki3's Avatar
wheel set up need help...!
Okay so i changed my mind about my old set up. I just order a set of rims.
19x8.5 offset 18 (front)
19x10.5 offset 25 (rear)
what tire size do you guys recommend? how to avoid vdc from going crazy.
will i need to roll any of my fenders? I am not dropped just yet. any advice will be much appreciated thanks.
Going on my 2003 G35 Coupe.
Last edited by itztwinki3; Dec 30, 2014 at 04:33 PM. Reason: forgot to add which model I had
Old Dec 30, 2014 | 11:01 PM
itztwinki3's Avatar
also not really trying to do any fender mods but if i have no choice with this set up then ill do since rims are well worth it.
Old Dec 31, 2014 | 02:07 AM
itztwinki3's Avatar
Anyone???? Please
Old Dec 31, 2014 | 02:26 AM
itztwinki3's Avatar
I just bought a set of rims.
I have a 2003 g35 coupe and have not lowered yet.
Rim set up
19x8.5 offset 18 (fronts)
19x10.5 offset 25 (rears)
Few questions.
1. Which tire size should I go with without any rubbing or fender mods?
2. How to avoid Vdc acting up?
3. If I lower the car how low can I possibly go before I have no choice to cut or roll my fenders?
Your advice and help is much appreciated.. Thanks in advanced.
Old Jan 1, 2015 | 03:17 AM
itztwinki3's Avatar
happy new year bump...
Old Jan 1, 2015 | 04:31 AM
bluedevils95's Avatar
happy new years! do you want to stretch look or just the normal look?
Old Jan 1, 2015 | 09:55 PM
the93owner's Avatar
I would go 245/40/19 front and 285/35/19 rear. If that's too much meat, drop to a 35 tire in front and 30 in rear.
Old Jan 1, 2015 | 10:20 PM
Lartytiejdke3's Avatar
Damn.
Whatever happened to the not being able to bump your own thread in <24hrs rule ?
Old Jan 1, 2015 | 10:38 PM
herrschaft's Avatar
How you want it to look is up to you. Use the tire/rim calculator above your post and keep the difference between the front and rear tires under 3%. It essentially answers all of your questions provided you have a ruler.
Old Jan 2, 2015 | 03:38 AM
itztwinki3's Avatar
depends really. i am putting in coilovers and rear camber kit was thinking about 1.5 inch drop front and 1 inch drop rear. how would i avoid do any fender mods? would i have to go stretched or normal? either or works for me as long as i wouldnt need to do fender mods.
Old Jan 2, 2015 | 03:44 AM
itztwinki3's Avatar
do you guys think the 19x10.5 offset 25 is too wide for the coupe? if so i can send it back and grab the 19x9.5 offset 35 and grab some spacers to bring the offset lower.? what do you guys think?
Old Jan 2, 2015 | 11:17 AM
the93owner's Avatar
I think 19x10.5 +25 should be fine, I ran the same width/offset with a 20 inch wheel and I wasn't rubbing. You could put a 275/35 on there, and it would stretch a little which should fit with no problems.
Old Jan 2, 2015 | 04:38 PM
itztwinki3's Avatar
thanks i appreciate it
Old Jan 7, 2015 | 12:50 AM
itztwinki3's Avatar
were u lowered at all? and did u do any fender mods at all?
Old Jan 9, 2015 | 11:10 AM
badmojo24's Avatar
Thumbs up
I just got some stance wheels 19x9.5 +20 front and 19x10.5 +20 rear. Not lowered. Not fender rolled. Using 245/35/19 front and 275/35/19 rear. Tires are stretched just a wee bit.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
