After putting my 19's(no drop) Do I need wheel alignment?
Old Feb 22, 2005 | 12:25 PM
TheEvilDragon's Avatar
I got my new rims a week ago. They are 19x9 and 19x10.5.
My car is still using stock suspension. Do I need to get a wheel alignment?
My car was running on 18s before.
Thanks
Old Feb 22, 2005 | 12:49 PM
kenchan's Avatar
Typically no, but if you're rubbing or scrubbing too much on the inside treads, then
you might want to get an alignment.
Also, some tires with agressive offsets will cause tramlining (or the effect of it) you
will want to get a tad more toe-in for straightline stability.
Old Feb 22, 2005 | 02:27 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
JMO, but................
An alignment is always a good idea.
I get it done right after delivery & then
I get it done annually after that.
Factory alignment can be very poor.
(usually within spec but poor)
It's surprising how much it changes over time
due to normal wear & tear.
It can really make difference in the handling of the car.
Old Feb 22, 2005 | 03:14 PM
giddyup69's Avatar
are they balanced? that's all i would do. when i got my winter rims/tires... i just mounted them. no problems with alignment.
Old Feb 22, 2005 | 03:21 PM
MorenoEnNYC's Avatar
Wow EvilDrago I'd love to see photos of the rear 10.5's I just hate it when G owners sell themselves short and opt for 9's or 9.5's in the rear.
Old Feb 22, 2005 | 05:25 PM
imalazeeass's Avatar
im assuming that since u got new rims.. a drop is going to happen sometime soon? Or are you even going to consider that? If so, then hold off cuz allignments aren't all that cheap. It's like $50? If not dropping, then u should def get an allignment. I checked my allignment when I had my car still at stock, and it wasnt even alligned to factory specs. Seemed like they don't really take the time to allign our cars properly before they put em out for sale..
rezendvous420
May 31, 2020 01:26 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
Jadenkid22
Jul 14, 2015 12:33 AM
