What spacers do I need to Run OEM 18" Sedan wheels on coupe
Old Nov 16, 2015 | 11:52 AM
Tylko Kazik's Avatar
What spacers do I need to Run OEM 18" Sedan wheels on coupe and keep the same offset as on my oem 19" rays ? I have a very hard time finding a set of 18" for a coupe in decent condition and there is plenty of sedan wheels out there . Thanks in advance
Old Nov 16, 2015 | 12:09 PM
gary c's Avatar
Question is...why would you want to down grade to sedan wheels?
Gary
Old Nov 16, 2015 | 12:11 PM
I want to switch to 18" and its hard to find coupe ones .
Old Nov 16, 2015 | 05:27 PM
GSpeedRevUp's Avatar
Do you mean offset?... Offside's is football and soccer. Well most OEM rims run about a +30 or +32 offset so you don't need to change it and usually it's +30mm in the front and +32 in the rear. This being because the rear rim is .5" wider than the front.
Old Nov 16, 2015 | 06:13 PM
Lartytiejdke3's Avatar
What lol
Just because a wheel is bigger doesn't mean the offset has to change or will change
And yes I don't think it needed to be corrected that the op wasn't talking about offsides in football in regards to his wheels
Op you mentioned a rough ride with your 19s here in jersey. Have you tried for a larger sidewall?
Old Nov 17, 2015 | 05:53 AM
Just clarifying... if I didn't do it someone else probably would have. I saved you the time on posting that early and not having to do it later.
Old Nov 17, 2015 | 08:27 AM
i made a mistake i wanted to write offset.
Old Nov 17, 2015 | 08:30 AM
What lol
I haven't tried larger sidewall because i dont think that will be enough, i dont want to get new tires just to be disappointed . I plan on getting brand new tires on the 18 with a larger sidewall. what are you running ?
BfloG35
18 Inch
Apr 27, 2017 01:13 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
saywat?
Sep 22, 2015 05:42 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
