Advice on wheel setup
Old Nov 25, 2015 | 01:36 AM
abstrakg35's Avatar
I'm looking at 18x8 +40 front and 18x9.5 +40 for my 2005 g35 sedan with stech springs I'm wondering if anyone else have this setup and what tires are you running I was planning on just swapping my 235/45r18 tires from my stocks also if you guys recommend spacers
Old Nov 25, 2015 | 06:54 AM
VenomGT9's Avatar
Even for a sedan those are fairly high offsets...will be sunk in.
As far as tires, you'll have a decent stretch on the rear with the 235, could bump that up to a 255
Old Nov 25, 2015 | 09:23 AM
Lartytiejdke3's Avatar
Check out SSR GTV03
same style-better wheel
Keep up the good work of keeping your car looking tastefully modded and classy
Old Nov 28, 2015 | 12:43 PM
GSpeedRevUp's Avatar
I wouldn't go +40mm offset on an infiniti ever, like Venom said the rim will be set inside the wheel well alot unless that doesn't bother you. Not sure how much it would effect handling but i notice with a lower offset rim and wider wheel i like the handling a lot more on my car opposed to a higer offset rim. +40mm offset rims are more of a Honda and smaller type car rim offset. If you want the flush look atleast go with +20mm offsets, and stock rims are +30mm, +32mm offset to give you a better idea. Goodluck.
Old Nov 30, 2015 | 08:49 PM
saywat?'s Avatar
either stay around stock or lower. never higher
Old Nov 30, 2015 | 11:29 PM
abstrakg35's Avatar
From my understanding my stock wheels shown in the photo are 18x7.5 +45
Here are some specs of the stock to what I was looking at getting
Old Dec 1, 2015 | 06:42 AM
Originally Posted by Darkness_S14
17" 5 spoke (model??)
Front & Rear: 17"x7" +40mm offset 5x114.3mm (5x4.5in) bolt pattern (aka PCD)
17" 6 spoke (model??)
Front: 17"x7.5" +30mm offset
Rear: 17"x8" +33mm offset
17" 7 spoke (2005+ Sedan std)
Front & Rear: 17"x7" (+45mm)
18" 7 spoke (2003/2004 optional 2005+ Coupe std)
Front & Rear: 18"x8" +30mm offset
18" 5 split spoke (2005+ Sedan optional)
Front & Rear: 18"x7.5" (+45mm)
19" 5 split spoke (2005+ Coupe optional)
Front: 19"x8" +30mm offset
Rear: 19"x8.5" +33mm offset
17" Wheels - double 5 spoke alloys (2007 Sedan)
- Front & Rear - 7.5" x 17" with 45mm offset with 225/55R17, V rated all season tires.
18" Wheels - split 7 spoke alloys (2007 Sedan)
- Front - 7.5" x 18" with 45mm offset with 225/50R18 W rated summer performance tires.
- Rear - 8.5" x 18" with 50mm offset with 245/45R18 W rated summer performance tires.
Sorry I stated the +30mm and +33mm offset from the 19" forged Rays rims I used to have not all the OEM rims... but here is the offset and size of most OEM rims for G35's posted from Darkness_S14 from another post. Again... anything at or above +32 offset your rims will set in the wheel well more. If that's fine with you, enjoy. Goodluck.
Old Dec 1, 2015 | 01:21 PM
saywat?'s Avatar
with the wheels ur looking at since its 2.5" wider than ur stock ones, half that and thats how much more the wheels will poke out (1.25") compared to stock since the offset is about the same. so if ur fine with the way the current wheels sit ull be a little happier seeing it pushed out an extra 1.25"
Old Dec 15, 2015 | 03:40 AM
abstrakg35's Avatar
Here is the front sorry for the crappy photo but I will tak a better picture tomorrow
Old Dec 18, 2015 | 06:29 AM
Nice upgrade... your in Hawaii your user name stats. How is the weather?... buy me a ticket and i'll go surfing and pick up some chicks with ya lol.
Old Dec 18, 2015 | 07:04 AM
abstrakg35's Avatar
Here is a photo of the rims on my car
Old Dec 18, 2015 | 10:02 AM
VenomGT9's Avatar
Not bad at all, well done
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
NJ6MT
Engine - Exhaust
Oct 11, 2015 05:50 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
