Will this fit
Old Dec 23, 2015 | 07:06 PM
Turbopseidon's Avatar
Will this fit
Will 245 40 19 +42 Offset 8.5 wide and 285 35 19 +45 offset 9.5 wide with coilovers on a moderate drop? Thanks
Old Dec 23, 2015 | 07:38 PM
G2B35AGN's Avatar
It will help to know the year and body style....
Old Dec 23, 2015 | 08:08 PM
2004 g35 coupe 6spd with brembos...
Old Dec 23, 2015 | 10:42 PM
Lartytiejdke3's Avatar
You need to know disc size first with the brembos
Old Dec 24, 2015 | 11:12 PM
I don't understand what does disks size have to do with width of the tires?. They fit with 18's on so 19's won't be a problem.
Old Dec 25, 2015 | 08:17 AM
First of all your first question made zero sense and it sounded like you were missing a bunch of words. However I assumed it was a wheel fitment question. If I'm right, you need to go research their disc sizes. It being an 18 or a 19 in this case and whatever offset they may be, does not matter when clearing brembos.
Perfect example. My oem 19" rays cleared brembos but my 20" vsxx didn't... See?
The seller of your wheels will be able to tell you this so you can know for sure
Old Dec 25, 2015 | 11:29 AM
i apologize for you not understanding my question. The front rims are 19",8.5 inches wide with a +42 offset
The rear rims are 19", 9.5 inches wide with a +45 offset
The question is will 245,40/19 fronts and 285,35/19 rears fit on the rim setup mentioned above.
I understand there may be a possibility of the rims not clearing the calipers. They came off of a g37.
I hope that makes it clearer.
Old Dec 28, 2015 | 10:52 AM
VenomGT9's Avatar
The tires will fit the wheels no problem however, those wheels will not fit your car...offset is way too high so you'll need at least 25mm spacers to get a good fit
Old Dec 30, 2015 | 10:17 AM
Thank you..
esotericrider
Dec 20, 2015 01:01 AM
dc2long
Dec 14, 2015 12:28 AM
eazdaskeez
Lighting
Dec 8, 2015 11:32 AM
Rcity
Steering & Suspension
Dec 7, 2015 09:54 AM
