19x8.5 +45 offset on sedan
Old Feb 26, 2005 | 02:12 AM
mark20001's Avatar
Does anyone know if 19x8.5 +45 offset all the way around will work on a sedan? I plan on lowering 1-2 inches.
Thanks
Old Feb 26, 2005 | 02:24 AM
Gsedan35's Avatar
A little too high for the front, would work with a 10mm spacer. What tire size are you going to run and will you never want to run any wider then that?
Old Feb 26, 2005 | 06:38 AM
skeleton_cru's Avatar
Sedan
+45 would be way too inset. +38 would be ideal.
Old Feb 26, 2005 | 04:20 PM
mark20001's Avatar
The size wheels I am looking at are PIAA Rozzo Supermesh 19x8.5 with +42 offset. The tires I am looking at are 245-35/40-19. I am not sure I want to go the spacer route since I would like the front and rear to both have the same location relative to the fender.
Old Feb 26, 2005 | 06:45 PM
Sedan
I think you might be OK with the +42 offset, but I'm not sure about the look. I tried a search for people with the same set-up but I didn't find anything. Maybe try a new post titled Anyone with 19x8.5 w/+42 offset on sedan? or something like that. Then you'll get a better idea of how it would look.
As far as the tires I recommend 245/40/19.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Soumilg
Jul 18, 2015 12:33 PM
