Calculating Tire Size
Old Feb 5, 2017 | 07:51 AM
Bval9's Avatar
Hello,
I have what I hope is an easy question for someone to answer. Calculating what tire size will work isn't exactly my area of expertise. I have searched the forum for this wheel size and offset, but haven't found any promising results.
Without starting the great debate about rep wheels, I was offered a set of XXR 551 wheels for free until I pick up something that I like. These wheels do not have any tires on them.
The wheels are 18x9.75 +22.
My car is Stock ride height. I've seen a few g35 with these wheels.
What size tires would work and would I require a spacer.
Brian
Attached Thumbnails Calculating Tire Size-img_1897.jpg   Calculating Tire Size-img_1898.jpg
Old Feb 5, 2017 | 09:36 AM
gary c's Avatar
There's a Tire Size calculator at the top of the coupe page among the sticky's, your answers are all there...Gary
Old Feb 5, 2017 | 09:57 AM
Bval9's Avatar
I appreciate the response. I can't find that stick under the 03-07 coupe page. I looked at the sticky in this forum for calculating tire size, but it wants a size entered to tell the difference from OEM.
I do not know what size tire I would even be able to run with these.
brian
Old Feb 5, 2017 | 07:24 PM
Blue Dream's Avatar
I drove ttrank's car solo
Brian one of the responsibilities of new members is to read and follow the forum rules. You will find that doing leg work on your own (searching for answers to your questions before posting them) is a rule, there are literally thousands of posts in this section that will answer your question for you to find. Happy hunting!!
Old Feb 6, 2017 | 08:16 PM
Bval9's Avatar
I found a post within a larger thread where someone referenced a similar wheel size but their car was lowered. I am hoping that these would also work for me... before I spend any money on this stuff, can someone who clearly understands this stuff better than I either confirm or deny that they'll work...
the rims are 18x9.75 +22
according to the post I read, it looked like 275/35 or 285/35 would work... I would prefer more meat on the rims, so probably 285...
Old Feb 7, 2017 | 11:34 AM
LoSt180's Avatar
You're main goal in calculating tire size is to end up with a tire that has the same overall diameter as your stock tires. This will keep things like your speedometer accurate and happy. Lowered or not shouldn't have any effect on a proper tire size.
So in the calculator, put stock size on one side, then the size you think you want on the other, if the diameters are pretty close then you should be fine.
Old Feb 9, 2017 | 07:24 AM
Bval9's Avatar
I don't mean to seem like a pest about this, but I won't be able to return these after I buy them (and it's not exactly a cheap expenditure)
245/35 for the front and it shows the first picture attached
265/35 for the rears and it shows the second picture attached.
The diameter difference is very small, there is a noticeable difference in the inner clearance and the outer clearance.
And to the first two replies on this thread, I understand the way that forums work and I recognize that searching and research are required. This is a subject that I am not well versed in. As I do not want to waste this sort of money on an area that I am really not all that comfortable in, I asked for help...
Attached Thumbnails Calculating Tire Size-front.jpg   Calculating Tire Size-rear.jpg
Old Feb 9, 2017 | 07:53 AM
Blue Dream's Avatar
Those tire sizes will work fine. Pull the trigger on them, get them installed and you're golden! You can let go of the stress of the decision and just enjoy your new shoes. I love having all new tires on my rides, makes them feel like a whole different vehicle.
Old Feb 9, 2017 | 08:39 AM
Bval9's Avatar
thank you very much for the help!
