What pads? PBR MM, or PBR Ultimate?
Old Mar 1, 2005 | 01:17 PM
roadracer516's Avatar
Need some opionions please? For 6MT, which pads? PBR Metal Masters or PBR Ultimates? I am looking for a good pad that reduces dust, but performs well? Thanks
Old Mar 1, 2005 | 06:45 PM
Q45tech's Avatar
How much less than oem performance are you willing to accept. What coefficient of friction in cold weather is good enough for you and your insurance company?
Generally the ABS software [slip ratio set point] is the limit for improving but getting too far away from oem curves has downsides in initial bite and stopping distances from 60-80 mph in single cold stops.
But we are speaking in/of 10-15 maybe 20 feet at the worst [~~10%] ranges mostly in the 1st 0.5 second build up [friction] rate........when traveling 88 feet per second [60 mph] the critical time is the first 0.5 second ramp-up to full friction........oem is a special fast wearing blend to get the nth degree in this critical time frame....thus the dust.
Changing the friction curves vs. temperature front to rear is very tricky and aftermarkets don't test on individual cars.....they just slap their compounds on oem copied pad backing plates.......and hope for the best.
In US there is no spec nor test for aftermarket vs. Europe/Japan where the pads must NOW [very recently] be tested [to at least provide 80% of oem performance] to be acceptable -----thus great amount of EXPORT DUMPING into US/Canada/England and other 3rd world now.
Old Mar 1, 2005 | 07:05 PM
WOW.....was not expecting that much information, but I applaud your knowledge! Cold weather is not much of a concern for me as I live in So Cal. You mention the difference being between 10-15 feet of stopping distance, that is a lot really! Are you implying that there is a big difference in the two pads I mentioned or both compared to the stock pads? Your help is appreciated
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
