View Poll Results: Which tire size
235 35 19
25.00%
245 40 19
75.00%
Voters: 4. You may not vote on this poll
19" Rays Coupe
Old Nov 18, 2017 | 04:27 PM
TheGuyGuy's Avatar
I replaced the knuckle, shock and stabilizer bar. Had a 4 wheel alignment since then
Old Nov 18, 2017 | 04:34 PM
TheGuyGuy's Avatar
Me smoking the curb happened about a year ago. I had an alignment done and they said something was bent still. They said it was 1 degree off. I’ve went about 9,000 miles since then and the opposite rear tire is wearing not the one that had the broken knuckle.
Old Nov 18, 2017 | 04:37 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, inspect everything under the vehicle including the differential, rims/tires (one pictured under the vehicle looks trashed/cracked but might not be for the G), etc. The force of the impact can damage a lot of stuff not at the point of impact.
Old Nov 18, 2017 | 04:41 PM
cleric670's Avatar
BANNED!!!
You can use flourescent dye and soak various components that might be broken, let them dry and inspect in a dark room with a black light, cracks will be obvious, or just replace everything if you can find a donor for cheap.
Old Nov 18, 2017 | 04:56 PM
TheGuyGuy's Avatar
The trailing arm is slightly bent which I have just didn’t replace because the way the body is made it seems like you’d have to cut out a small section to get the bolt out or drop the whole sub-frame which is retarded. I just cleared my knock sensor code and drove around for about a hour and it’s back. Along with C1105. On 2 different scanners this says LR ABS sensor 2 but on the net it says RR. And the wheels were already scraped up but did get scraped worse. I’m not too worried about it. I have a convertible Z in mind for a very nice price and with less miles than my G had when I bought it. About 20k less miles. Just needs some body work done to the rear bumper cover.
Old Nov 18, 2017 | 05:15 PM
TheGuyGuy's Avatar
I am definitely holding on to the G tho...
Old Nov 18, 2017 | 06:14 PM
Urbanengineer's Avatar
Ah I see. Interesting man.
