Varrstoen Wheel Set Up Help
Old May 26, 2018 | 06:09 PM
BGonzalez2597's Avatar
Recently picked up some Varrstoen Es2 (Te37 reps) 19x9.5 up front & 19.10.5 in back with +12 offset all around. I did a lot of research about these specs before I bought them and know that they work but the only info I could not find is if I will need to roll all of my fenders or just rears. I’m lowered on 350z Tein S-techs and am not planning on installing the new wheels till I replace my front lower control arms so I have no idea if I will be rubbing. Any help is appreciated.
Old May 27, 2018 | 12:44 AM
ScraggleRock's Avatar
Well, first if all, front are rolled from the factory
And second, get rid of those awful wheels.
Old May 27, 2018 | 08:24 AM
Blue Dream's Avatar
I drove ttrank's car solo
We need to know what size tires you're planning on running before we can answer your question. You might need to add more negative camber in the rear if you're going 265 or wider on the rear and you'll need to buy aftermarket camber arms as the stock adjustment won't be enough.
Skilled
Aug 16, 2010 05:38 PM
