Unidirectional Tires..
Old Mar 5, 2005 | 11:21 AM
flipmoder7's Avatar
I recently noticed I put my winter tires on the wrong way (stupid mistake ). By this I mean I placed them wrong from side to side, but I did place the rears and fronts in the right location. I drove like this for two months and just noticed it now. How bad did I damage the tires?
Old Mar 5, 2005 | 03:51 PM
kenchan's Avatar
not much if at all. You just didn't get the max traction you should've got, that's all.
Old Mar 5, 2005 | 04:04 PM
Buddha's Avatar
at least once you correct it, your tire will wear evenly
Old Mar 5, 2005 | 05:56 PM
flipmoder7's Avatar
I switched them today. Thanks for the help.
Old Mar 6, 2005 | 02:16 AM
Sandman's Avatar
On tirerack.com they did an interesting test where they ran Goodyear Eagle F1 GS-D3 Max Performance tires on a 2003 SVT Cobra Mustang on a wet and dry track with the tires mounted correctly, then backwards. They were somewhat surprised to find that there was very little performance difference either way. Not sure how this applies to snow tires, though. This was their note at the end:
NOTE: If directional tires are accidentally installed backwards during initial installation or following tire rotation; the driver should simply reduce speeds in the rain and have the tires installed correctly at the first opportunity. Running directional tires backwards for a brief period of time will not hurt their internal structure.
Here's the article: What Direction Shoud You Go to Resist Hydroplaning?
Old Mar 6, 2005 | 02:38 PM
Q45tech's Avatar
Most of the "directional effect" was a marketing hype invention.
Absolutely non worn directional tires are usually better [3%] in rain hydroplanning speed till they wear out [lose the edge] in 5,000 miles. Half worn directional tires may be worse than equal depth non directionals depending on road water depth.
A few things the ads forget to mention.
Same with noise tuning reduction quieter till 5,000 miles then much louder as the acoustic cancellation changes.
joedaddy1
Jan 3, 2008 07:25 PM
johnadlertech
Nov 29, 2006 01:20 PM
flhtvtwin
Sep 14, 2005 07:57 PM
steveinmd
Aug 27, 2004 09:22 AM
G35MD
Apr 6, 2003 06:00 PM
