Those w/ 19x9.5 & 19x10.5...
Old Mar 9, 2005 | 12:16 AM
Cruz's Avatar
& anyone else who wants to provide input, a few questions...
-Are you happy w/ your setup?
-Any pros or cons?
-What size tires & suspension are you running?
-How's the ride?
-Any rubbing or fitment issues?
Old Mar 9, 2005 | 01:16 AM
1Gig's Avatar
-Are you happy w/ your setup? Definitely
-Any pros or cons? Pros: Personalized Car Cons: Hard to clean
-What tires & suspension are you running? S03s & Tein Basics
-How's the ride? Stiffer then stock, but better handling
-Any rubbing or fitment issues? None
Old Mar 9, 2005 | 01:23 AM
Cruz's Avatar
Thanx 1Gig...although I meant to ask what size tires are you running?
Thanx
Old Mar 9, 2005 | 01:42 AM
Kyosho's Avatar
- of course, you can never go too wide
Any pros or cons?
- looks great, more expensive
-245/35/19 front, 275/30/19 rear (also S03s), tein s-techs
How's the ride?
-nearly identical to stock, more stable at high speeds.
-none yet, but springs havent completely settled
Old Mar 9, 2005 | 03:34 AM
ZeroGen's Avatar
Omega Enthusiast
My set is expected to arrive sometime next week or so and I'll be running 19x9.5 front and 19x10.5 rear. I'm planning on getting 255/35/19 front and 285/35/19 rear tires. I don't expect the ride to be much different than stock. You can go 245/35/19 front and 275/35/19 rear tires with the 19x9.5 front and 19x10.5 rear, respectively.
Old Mar 9, 2005 | 03:38 AM
Cruz's Avatar
ZeroGen, what wheels are you going w/ & what suspension are you running?
Old Mar 9, 2005 | 02:25 PM
bzabodyn's Avatar
yeah, I 2nd that - what wheels/tires are you going to be rockin'?
I should be able to have you a nice answer by the weekend if my wheels come as scheduled... seems the shop is getting a kick out of making me wait longer than necessary...
Old Mar 12, 2005 | 12:43 AM
ZeroGen's Avatar
Omega Enthusiast
I'll be running Weds Sport SA-90 Forged; 19 inches & ~19 lbs each wheel. Talk about light! They're bronze in color and I think it will go well with the Twilight Blue. An update on the tires, I'll most likely run Bridgestone RE050A 255/35/19 front & 275/35/19 rear. I have a feeling that the rear may look a little "stretched" width wise on the rim but shouldn't be too bad. If I go 285 for the rear, I'm somewhat limited on tire selection. On top of that, can't go wrong with Bridgestone tires. I'll post pics once I get them installed.
For now, I'll be running stock suspension but I am considering Zeal V6 or Moton Club Sports coilovers (if they ever come out with them) along with 350evo camber kits....
brownie
Nov 25, 2015 12:50 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
the93owner
19 Inch
Sep 23, 2015 03:03 PM
