help on springs
Old Mar 10, 2005 | 01:15 PM
TonyZ_G's Avatar
help on springs
i want some springs that lowers the car @ 1.8 in the front and 1.6 in the back
and i want to keep the ride close to stock as possible.. and also i do not want to get camber kit either
Old Mar 10, 2005 | 01:26 PM
kenchan's Avatar
that's a tough one... after you drop close to an inch on the coupes you'll probably
want to get rear camber rods unless you got some super wide wheels/tires on
and need the extra neg-camber for fitment. The neg camber on the rear can get
as bad as -4.5 at a 1.4" drop (I know, my prokit rear was like that, now sitting
at about -2.5 using stillen rods. I can get it back to spec using toe
adjusters, but since the front is sitting at -1.8, i want a tad more
neg camber on the rear for street).
Drop wise, I think the Sprint springs are closest (from what ive read) to that
drop. next would probably be Eibach Prokits.
Old Mar 10, 2005 | 04:46 PM
DaveB's Avatar
Sorry to say, it's completely impossible.
Old Mar 10, 2005 | 04:52 PM
G2G's Avatar
G2G
What springs would be recommended for a coupe with out having to change nothing but springs. So basically what I am saying is what springs can I get away with by just swapping out springs and not run into any problems. How much will they drop the car? TIA
Old Mar 10, 2005 | 06:04 PM
CrazyMike's Avatar
Tia,
The closest thing would be 350z springs which have the same spring rate, but are 1/2" lower. However, you can't change the springs on the coupe and keep your camber within allowable specs. I posted on this earlier: https://g35driver.com/forums/showthr...er+camber+350z
As you can see even folks with 1/2" lower springs were OUTSIDE allowable factory camber specs. From what I've seen, if you want to lower your coupe and want to keep your camber in spec, you must buy the aftermarket camber adjusters. If someone can prove this hypothesis wrong, I'd love to see it!
Mike
Old Mar 10, 2005 | 06:30 PM
NORCALSTI's Avatar
350Z TEIN HS ALL THE WAY!!!!!!!
i just installed these in my g35 coupe yesterday
front is 26 1/4 from ground to fenderlips rear is 26 3/4 from ground to fenderlips. im going to cut rear bumpstops up top to get another .5 inches out of the rear
THE RIDE IS SWEET handles better and car doesnt break your back when you hit bumps!!!
Old Mar 10, 2005 | 10:21 PM
kenchan's Avatar
norcalsti- you should wait at least 3 weeks before changing anything. the springs will settle over time. also, you mean the rubber spring mounts right? not the bumpstops.
edit:
crazymike is right. Also, some of our cars already come with close to -2 on
the rear out of the box. drop it even slightly and you're out of spec.
My car is one of them. 1in drop and it was like -3.5 on the rear with
proper toe-in.. another .4" and over -4. so got the rear rods.
If i ever decide to bring the front back to spec i'll also get the rear toe
adjusters...but not in the near future. car runs good enough for me.
Old Mar 11, 2005 | 01:02 AM
beangrower's Avatar
Originally Posted by CrazyMike
Tia,
Mike
haha, I think he meant TIA as in "Thanks In Advance", not as his/her name being "Tia". sorry, not much help. Just thought it was funny.
Old Mar 11, 2005 | 01:25 AM
G2G's Avatar
G2G
Thanks for the info guys!
Old Mar 11, 2005 | 02:10 AM
NORCALSTI's Avatar
YAH THE RUBBER spring mounts. takes 3 weeks ahhh
what does your guys car measure from ground to fenderlip
Old Mar 11, 2005 | 09:49 AM
CrazyMike's Avatar
Whooops! Sorry G2G! I guess I'm still a forum-lingo Noob!
Old Mar 11, 2005 | 10:36 AM
haze's Avatar
I guess you can also go with Tein H-tech.
It lowers by .6/.3
Quite subtle that it wouldn't go too far off factory spec.
Old Mar 11, 2005 | 02:18 PM
kenchan's Avatar
imho, if you're only doing a little drop like less than one inch I would not
touch the springs and just leave it stock.
Old Mar 11, 2005 | 03:00 PM
TonyZ_G's Avatar
lol was talking bout the sedans but yea =/ sorry for not being specific
Old Mar 11, 2005 | 03:04 PM
G2G's Avatar
G2G
LOL (laugh out loud) no problem
Steve
