Wheel offset for my 2007 G35X sedan
Old Oct 10, 2021 | 10:11 AM
msi1337's Avatar
I am interested in buying some new Konig Oversteer rims for my 2007 G35X Sedan. The wheels are 19x8.5, but I am not sure if I should go for +30 or +45 offset. Could I please get a suggestion? I want to run a square setup.. also, what size tires should I be using?
Thank you!!
Old Oct 12, 2021 | 11:47 AM
herrschaft's Avatar
I never tracked offsets for the sedan, but one of the "stickied" threads in this section tells you the offsets of your current wheels. Use a wheel/tire Calculator, which I believe is also a "stickied" thread to determine which offset you want. The wheel calculator will tell you how much further a particular wheel will sit out compared to your current setup.
Tires are completely subjective but definitely keep it a square setup.
MVPea
May 27, 2012 07:46 PM
unervous
Oct 10, 2010 03:10 AM
mattpan
Feb 2, 2007 04:52 PM
meng702
Jan 28, 2007 11:55 PM
