wheel alignment & camber question?
Old Mar 13, 2005 | 10:13 PM
ILuvG35's Avatar
i just lower my sedan with 350z spring & suspension. and this is what it come out:
left front
camber -1.0
caster 8.8
toe 0.10
right front
camber -1.5
caster 8.3
toe 0.07
left rear
camber -1.7
toe 0.10
right rear
camber -1.7
toe 0.14
do you guy think i need a camber adjustment kit?
and should i set the toe so both left & right wheels are the same?
Old Mar 13, 2005 | 10:27 PM
sherwooa's Avatar
You should get a camber adjustment kit if you mind the additional wear on your tires. If you don't mind the additional wear and enjoy the handling benefit, then you can leave it. As of now you are out of spec, but not horribly.
As for toe, it's total toe that's most important, but yeah, you should try to get them even if you can.
Old Mar 13, 2005 | 11:55 PM
kenchan's Avatar
i wouldn't worry about your camber...but with your toe-in I think your thrust
angle is off.
you have a lot of total toe-in on the front too. Usually I target around .10
on the total front, .30 on the total rear.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
beevanhuynh
Jul 23, 2015 01:37 AM
Soumilg
Jul 18, 2015 12:33 PM
