Wheels Bolt Pattern Help!
Old Mar 16, 2005 | 02:57 PM
BigTyminRolla's Avatar
I know our cars have a 5x114.3 bolt pattern, is there any way 5x120 bolt pattern would fit on my car? (04 G35 Coupe, Auto). Please let me know, as I am getting a sick deal on some wheels (19x7.5 with 225/35 tires). Thanks.
Old Mar 16, 2005 | 03:07 PM
GXCLUSIV's Avatar
Is there a removeable center cap, if so what you can do is take it to a wheel repair shop, some can and will do a fill and drill. They will fill the holes and drill 5 new holes. Another option, depending on what the wheel center looks like, we had a custom BMW wheel bolt-pattern drilled over the existing hole for the 5x114.3 to fit a 300zx. So yes its possible, just need to find a shop that is experienced. You may need to use spacer depending on the wheel offset.
Old Mar 16, 2005 | 05:47 PM
AmistadUSA's Avatar
5x120 for BMW - NOT FIT.
19x7.5 with 225/35 tires - NOT FIT.
You think you got a deal - NO: you are wasting your $
Old Mar 16, 2005 | 10:31 PM
Thanks for the help, I guess I'll keep shopping around.
Old Mar 17, 2005 | 10:38 AM
panda007's Avatar
With the extra funds to drill new holes and spacers on some existing wheels, it is better and more reliable just to buy new/used wheels specific to the g. I don't know how reliable a modified wheel.
I had blitz technospeed z1's from a mkiv supra onto my car. Fronts needed a spacer while the rears fit fine however was an inch too far in. The plastic cover that guarded the fuel line (or whatever beneath the cover) was worn to the lines. The front extended nuts fell off and grinding a rotor from within (could have caused far worse detrimental effects)! It wasn't pretty... not to mention not worth the money nor time.
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
