SPC camber bolts
Old Mar 24, 2005 | 02:36 AM
g35thanh's Avatar
SPC camber bolts
hey, i have a few questions. I lowered my car and now i have some camber issues. mostly in the front, so i definitely need a camber arm for the front. the rears are showing some negative wear, but not as bad. can i just purchase the spc camber bolts for the rears or do i need a whole camber kit?
Old Mar 24, 2005 | 09:58 AM
afr0puff's Avatar
Supa Dupa Moderator
How much did you lower the car by? If you are only going down about an inch, I don't think you need to worry too much about the front. And you can get by with just the bolts. http://iapdirect.com/item.asp?invid=785
Old Mar 24, 2005 | 11:22 AM
g35thanh's Avatar
I'm over an inch in the front and I already had to throw away some toyos that still had 60% tread..the rears aren't wearing out on the inside as bad, but its noticeable. i think an alignment might do the job for the rears.
Old Mar 24, 2005 | 11:35 AM
nismoGcoupe's Avatar
I had the same problem I had to throw away perfectly brand new toyos with only 7K on them, but in the front I dont think the camber is your problem its you toe thats really crucial to tire wear. I have about 1.5" inch drop and my front camber was -1.8 compared to my rear -2.4 but my toe was OUT which made them wear very quickly, from what Im told I dont need front a-arms they should wear pretty evenly now that the toe is corrected. also for the rear you can save money and just get 2 set of the SPC bolts use 1 set for toe and the other for camber.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
6spdGspot
Oct 5, 2015 01:55 PM
