SPC camber arms and bolts, install?
Originally Posted by sen_jen
i guess Beangrower will be installing mine whenever i get to it, lol! thanks Beangrower. *holds up crown and coke for a cheers*
>burp<*
no, those aren't - those are what's called "traction bars" - like I said above, they do NOT directly adjust toe (only the toe bolt as mentioned above can do that) - they change the toe setting by throwing all the other suspension geometry off...
I understand now. This picture clearly shows the camber/traction arms and where you would modify the toe bolt (with the red arrow).
Originally Posted by Deang35c6
Look at the pic in the link. Isn't the area in the blue circle and indicated with the red arrow not where you would elongate and add the new toe bolt? Now you're really confusing me.
yes...i have done it successfully on 10 cars now.
Originally Posted by kenchan
e? these are toe rods. some call it toe arms....
Originally Posted by nismoGcoupe
This is the wrong way to adjust your toe, when adjust with these arms it will get your toe in to spec but it going to throw off caster. The only correct way to do it is with the bolts.
Chad
Though expensive, both 350EVO and Jic offer a non adjustable rear radius rod package. This is the same arm that you guy's are correctly ID'ing as the wrong place to adjust toe from. 350EVO call's it a trailing arm and Jic call's it a traction rod. Key reason to us them has nothing to do with trying to adjust toe as these two arms CANNOT adjust their length. You would use them to get rid of a bushing flex point that allow's load induced suspension geometry change (bad thing). Both these arms feature sperical bearings that do not flex under load vs the oem suspension's soft rubber bushings. Just wish they weren't so expensive. http://shop.store.yahoo.com/hopup1/jicmaretrrod.html
I have the Kinetics adjustables, but I will make sure my installer knows to make the traction rod the same length as stock before installing. Pretty easy, just install and adjust, then run bolt through before elongating, lock in place, then do the toe bolt mod.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
