19x8 and 19x10 tire size ?'s
Old Mar 27, 2005 | 05:26 AM
ballinG35's Avatar
I just ordered some jlines in those sizes and was recomended 235/35/19 for the front and 275/30/19 (only 275 size the tires I want have) in the rear. what are pros and cons of that setup?
Old Mar 27, 2005 | 04:30 PM
ballinG35's Avatar
anybody?
Old Mar 27, 2005 | 05:38 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
I,m runing 255-35-20/285-30-20
check sig...
only rubs up driveways when turn. very little..
no big deal
but these look fatttttt on road
<img src="http://i3.photobucket.com/albums/y78/g35ny/mycar.bmp" alt="Image hosted by Photobucket.com">
Old Mar 27, 2005 | 05:46 PM
areddy14's Avatar
i had the same question. i think i'm going to go with 245/35/19 and 275/35/19 for some 19x8 and 19x10 rims.
Old Mar 27, 2005 | 10:29 PM
graphite6mt's Avatar
what tire size do everyone recommend on 19x8 and 19x10? is 245 on the 19x8 okey?
Old Mar 27, 2005 | 11:33 PM
areddy14's Avatar
after talking to some people i decided on going with 235/35/19 and 275/35/19. i think that's what you should go with.
Old Mar 28, 2005 | 06:21 PM
ZeroGen's Avatar
Omega Enthusiast
You could also run 245/35/19 front and 285/35/19 rear.
Old Mar 28, 2005 | 06:35 PM
RashMan1450's Avatar
For that setup on 19's you will need to go with the following setup so the darn VDC is happy.
Front 245 - 35 - 19
Rear 275 - 35 - 19
yo gotta go with this setup so the VDC is happy.
Old Mar 28, 2005 | 07:18 PM
areddy14's Avatar
do u think i'll be ok with 235/35/19. james from creative auto works told me to go that route and i already placed an order for tires.
Old Mar 28, 2005 | 07:37 PM
ballinG35's Avatar
same here. Will the 235 series tire be thinner than the 245? I'm not to hip to all what the number mean (except for the diameter of the wheels)
Old Mar 29, 2005 | 03:47 AM
I would do the 245, reason being it protects the wheels better if for "knock on wood" you hit a pot hole you will have more protection.
Im running a 245 and no problems. look at my pic i posted in the thread on the DPE wheels and you can see the front wheels.
you can do 235 but make sure the series (the middle number) is 35 for 19s. 30s will make the VDC go crazy
Old Mar 29, 2005 | 04:08 PM
ballinG35's Avatar
so the 245/35 and 235/35 have the same tire height, but the widths are different, correct?
Old Mar 29, 2005 | 04:21 PM
AmistadUSA's Avatar
19x8 is too small for Coupe but 19x10 is too big for Sedan, weird set up
Old Mar 29, 2005 | 06:10 PM
Jahan's Avatar
The car will understeer a TON with that setup.
Old Mar 29, 2005 | 07:02 PM
ballinG35's Avatar
Why is 19X8 too small for the front of a coupe? What's wrong with 19x10 for the coupe? hhhmmm, wtf are you talking about? There are MANY people with custom wheels on their coupes running those sizes, and you act supprised to see them listed in this thread?
