Eibachs - 350s vs G35 coupes why the difference??
Old Mar 30, 2005 | 11:02 PM
gwhizz35's Avatar
Can anyone tell me why Eibachs on a 350Z lowers the rear more so than on the G35 coupe? The Eibachs on a 350Z lowers it rear perfectly, just enough to tuck the wheel a bit. The Eibachs on a G35 Coupe doesn't even come close. Anybody know why? Also, does anybody know of a spring in the rear that tucks the rear or at least come close on the Coupe?
Old Mar 31, 2005 | 12:32 AM
Omar's Avatar
Head 'n Shoulders
my eibachs make my car sit right above my tires. i can fit only my finger between the tire and the fender. Did you just get em put on? Wait for a little while and they will lower a bit more.
Old Mar 31, 2005 | 07:25 AM
Q45tech's Avatar
When you have soft spring rates [once corrected for motion angles and trigometric attachment points] a 10% ERROR is stiffness per inch translates to a 35% difference in ride height.
I always wonder whether people are measuring with their body weight in seat or unloaded..............100 pounds [140 >240 driver] can lower the body roughly 0.4-0.5".
Full or empty gas tank, passengers or no passengers.
Just like alignments must be done with the weight as you drive the car so must spring adjustments.
chinee
Jun 10, 2024 07:48 PM
wonderizm
Sep 24, 2015 03:09 AM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
