Volk LE37 in Gold
Old Apr 5, 2005 | 10:27 PM
G-fanatic's Avatar
Volk LE37 in Gold
I just sold my LE37's because I wanted more lip. I came across these pics and am shocked by the lip size. Is there any vendor out there that can tell me what offset these could possibly be and if you can get them. I'm willing to purchase asap.
Attached Thumbnails Volk LE37 in Gold-evo710_4.jpg   Volk LE37 in Gold-evomeetem5.jpg   Volk LE37 in Gold-evomeetem6.jpg
Old Apr 5, 2005 | 10:35 PM
Dru Dragz On's Avatar
The fronts are 19x9.5 +12 offset. I think I read that from somewhere.
Old Apr 5, 2005 | 10:40 PM
G-fanatic's Avatar
Would I be silly to assume that the smaller the offset the bigger the lip?
Old Apr 5, 2005 | 11:08 PM
mike552's Avatar
The offset has nothing to do with the size of the lip. I'm not a wheel expert, but from my understanding, the offser is the distance from the "flush" of the inner part of the rim to the part where the hub is. So, the smaller the offset number, the further away a rim will be from the inner wheel well. And then, depending on the wheel itself (the width) the more it will stick out of the side of the car.
So basically, a 20"x9.5" wheel with a +12mm offset, will stick out (or appear more wide) than the same wheel with a bigger offset. (i.e, +35mm), In this example, the wheel with the +12 offset will stick out almost an extra inch.
Old Apr 5, 2005 | 11:46 PM
Kyosho's Avatar
holy crap those are hot!
Old Apr 6, 2005 | 12:33 AM
paranormal's Avatar
those in gunmetal would look sooo hot!
Old Apr 6, 2005 | 01:10 AM
martyg35's Avatar
mine are gun metal
Old Apr 6, 2005 | 01:21 AM
paranormal's Avatar
Originally Posted by martyg35
mine are gun metal
and i was right! haha
Old Apr 6, 2005 | 01:28 AM
paranormal's Avatar
if they came in 20's i would have been all over them
Old Apr 6, 2005 | 01:32 AM
martyg35's Avatar
That's Mike's car from Evolution, those were old pics, check out his new setup
http://www.evolutionautosports.com/g35mike.htm
Talk to Jeff from Evolution if you want the same set up for the LE's as Mike .He's the guy that I got my wheels from.
phone 703.961.9090
Old Apr 6, 2005 | 01:40 AM
accordfreak's Avatar
he had to use a spacer for the brembo brakes. if you don't have brembos then it'll probably fit no problem. check to make sure
Old Apr 6, 2005 | 01:44 AM
martyg35's Avatar
True that... My front setup for the 9.5 didn't have much lip because of the brembos but I had no problems with the 10.5 rear with more lip
Old Apr 6, 2005 | 02:24 PM
tig488's Avatar
Thats the same setup, they are 19x9.5 +12 in the front and 19x10.5 +22 in the rear. The front have a 3mm spacer to clear the stock brembo front caliper. the offset does affect the lip size. they are very nice.
Old Apr 10, 2005 | 07:29 PM
G-fanatic's Avatar
If I get a 19x9.5 +12 in the front with 245/35, will I have any rubbing issues if I don't lower and have no Brembos? Anyone see anything wrong with this setup.
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
neight
Aug 3, 2015 11:27 AM
