Those that want rotors, please look here!
Old Apr 6, 2005 | 05:50 PM
G352NV's Avatar
Never enough
https://g35driver.com/forums/showthr...606#post507606
Old Apr 6, 2005 | 08:01 PM
afr0puff's Avatar
Supa Dupa Moderator
Since I can't post in that thread...
I'm very interested, but wanted to know if you could get some answers for me:
Are these for performance street and Auto-x use only? Or can they withstand the rigors of track use as well?
What brand "blanks" do they use (6MT version)?
For the Brembo Caliper group buy group - is it going to be cross drilled/slotted, slotted only, or cross drilled only?
Does the hub have to be powdercoated black?
Old Apr 6, 2005 | 09:01 PM
G352NV's Avatar
Never enough
Slotted and drilled, I think the hub has to be black. Ill ask him about track duty.
Old Apr 6, 2005 | 11:23 PM
speedeezx's Avatar
very interested, quick question's first.
For the non-brembo, is the rotor larger than stock or the same size just slotted/drilled?
Can I expect a significant improvement/bite with this upgrade? I realize if it is a larger diameter than the answer is "yes" if not than ????????
I've been on the look out for just a rotor upgrade but I've been unable to find an upsize rotor with new caliper mount without jumping into an 1800.00 kit including new calipers. I went to 19" rims and the braking is considerably different than with the 17's on and I'd like my "feel" back.
Thanks - Doug
Old Apr 6, 2005 | 11:27 PM
G352NV's Avatar
Never enough
You cant upgrade your rotor without doing the caliper. The caliper bolts to the control arm, if the rotor was bigger it wouldnt fit. Yes you will get more bite.
Old Apr 7, 2005 | 01:06 PM
G352NV's Avatar
Never enough
Ok he got back to me. He said that they are for street use. Blanks are made by them.
Old Apr 7, 2005 | 01:44 PM
g35thanh's Avatar
this is a good deal too
http://performancenissanparts.com/ca...oducts_id=3424
Old Apr 7, 2005 | 02:11 PM
afr0puff's Avatar
Supa Dupa Moderator
Thanks for trying though.
Old Apr 8, 2005 | 05:33 PM
G352NV's Avatar
Never enough
Bump
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
