Will these fit?
Old Apr 13, 2005 | 01:02 AM
35coupe's Avatar
Will these fit?
19X8.5 all around 235-35-19 tires.
+38 offset on a 05 g35 coupe MT6
Old Apr 13, 2005 | 01:31 AM
vleo8181's Avatar
Do you happen to have the brand?
Old Apr 13, 2005 | 01:38 AM
35coupe's Avatar
oh sorry, BBS CHS
Old Apr 13, 2005 | 01:59 AM
vleo8181's Avatar
You also want to have a staggered set-up...unless you want your tail end whippin' everywhere.
Old Apr 13, 2005 | 09:13 AM
LUV2DRIVEMYG35's Avatar
Correct. The stock set up is staggered horiz and vertically. You'll be losing some rubber in the rear which will work against you on hard launches and hard cornering, and you're also reducing the rear diameter quite a bit. Stock front/rear dias. are 25.8" and 26.8" respectively and your new set up is 25.5" all around. You may run into issues with VDC, ABS, false odometer readings. You're also going to need to be at a slightly higher RPM to maintain the same speed as you would stock. With an 8.5 width, I'd go 235/35/19F / 245/40/19R or 245/35/19F and 255/40/19R to maintain rubber in the back and keep staggers as close to stock as possible.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
