Best All Season Tires? Pilot Sport A/S?
Originally Posted by blindspot
I just put on pirelli p zero all season tires and they stick like glue. Have not been able to spin out yet (245 in the front and 275 in the rear on stock 18's). From what i've heard they last longer than the pilots.
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
Top five (in order) according to Tirerack.com:
1. Pirelli PZero Nero M&S
2. Avon Tech M550 A/S (never heard of this brand tire before!)
3. Michelin Pilot Sport A/S
4. Continental ContiExtremeContact
5. Kumho ECSTA ASX
6. Yokohama AVS dB S2
I've got the Michelins. I like them in every respect EXCEPT tread wear. The center of the tire wears out far too quickly in my opinion.
5. Kumho ECSTA ASX
You can take a look at the Toyo website, but most of them in 17" are 45 sidewalls. I am not expert on sizes and don't have much experience with the coupe 17s so maybe someone can help him out.
I think maybe u can try 235/45 R17 in front and 245/45 R17 in the rear. This is won't throw your speedo off (same diameter) but the sidewall is thinner and ride might be slightly stiffer. I don't know the width of those 17s so this is the best advice I can give ya if you want Proxes 4.
Thanks Renesis...that is the type of info I'm looking for.
I'd like to stick with the 17's as $$ is tight right now. I'll check out the Pirelli's
Can someone chime in and let me know if the 235/45's will be ok instead of the 50's
Also is it poss to go with 245's on the rear of the stck 17's?? Instead of 235's
Thanks all.
I like both the Pirelli's and the Toyo's mentioned above. Good prices too!
Thanks all.
It is absolutely OK as long as the tire can fit on the wheels. Do you know the width of your wheels??
The general rule for tires is, if width increases by 10, then sidewall decreases by 10.
That way, the diametere of your tires will always stay within 1% for sure.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
