How am i lookin?
Old Apr 19, 2005 | 09:39 PM
ChuckP's Avatar
How am i lookin?
Ive let my s-techs settle for about 3 weeks now and my 19's been on for about a week. I just got an alignment to see where i stand and if i need a camber kit. I went to a well respected shop, and he told me that im cool at all 4 corners. I know the fronts arnt within spec, but he said that he turned the toe in more so that the tires will wear more even, is this true? Anyways i just want your guys opinions on how im lookin, just so i can sleep better tonite....
Front Left --- Front Right
-1.4 Camber: -1.6
8.8 Caster: 8.8
.08in Toe .08in
Rear Left --- Rear Right
-1.8 Camber: -2.0
.15in Toe: .14in
Old Apr 20, 2005 | 12:01 AM
kenchan's Avatar
the setting looks ok, but I think you can go a little less on the front toe-in.
More toe-in will cause faster inter tread wear. My total toe-in on the front is 0.09
where as yours is 0.16. not bad though. but if you're going for performance,
leave it. it'll give you better straightline stability.
Old Apr 20, 2005 | 12:05 AM
OvaYahead's Avatar
going by the specs on my sheet everything looks right at the limits or a little above. I would sleep better if my fronts where corrected like yours.
Old Apr 20, 2005 | 12:14 AM
kenchan's Avatar
chuck- is that in inches "in" or degrees? if inches, you're quite a bit toe-in....
Old Apr 20, 2005 | 12:41 AM
haze's Avatar
is that the s-tech for the G?
Old Apr 20, 2005 | 03:26 AM
ChuckP's Avatar
kenchan- the toe is in inches, the camber is degrees.
haze- yes s-techs for the G
I drive my G agressively, but never gets tracked, just 1/4 mile runs every few weeks. You guys think its a good setup for even wear and a good life from my rubber? thats all im really looking for. BTW the tech said that the increased toe in, in the front was for more even wear? im a little confused....
Old Apr 20, 2005 | 01:45 PM
kenchan's Avatar
chuck- you got too much toe-in then. watch your inter-tire wear. If you see
excess amounts, go back and get the toe-in reduced.
Zeo
Oct 30, 2004 05:13 AM
SuperCharged6MT
SouthEast
Feb 17, 2004 10:38 AM
DallyCurtis
Jun 21, 2003 05:40 AM
