jewlers rouge & buffing wheels for lips?
Old Apr 20, 2005 | 12:42 PM
waijai's Avatar
i.love.gold
My iForged lips are starting to get hazy from all the hairline scratches on them. Has anyone ever used buffing wheels attached to a drill with jewlers rouge to buff them to a shine? I currently have been using wenol applied with a terry cloth towel, but it's a big chore to get them really sparkling. If I can attach a buffing wheel and just whiz away on the lips it would make it 100X easier.
This is what I had in mind.
http://www.hobbytool.com/index.asp?...PROD&ProdID=430
Old Apr 20, 2005 | 12:54 PM
Diesel1's Avatar
Moderator
Are the lips clearcoated? If they are, you can forget the polishing kit. If not, then it should work. Keep in mind you will need some high speeds to do the polishing. I doubt a regular drill would allow ya do get the speeds up fast enough. A dremel should work but it will take you forever.
Old Apr 20, 2005 | 01:11 PM
waijai's Avatar
i.love.gold
no clearcoat on the lips
Old Apr 20, 2005 | 02:23 PM
OvaYahead's Avatar
can you polish iodized lips?
Old Apr 20, 2005 | 02:32 PM
CreativeAutoworks's Avatar
I dont know about other products, but i do know that mothers mag polish does not recommend using it on a inodized finish.
Old Apr 20, 2005 | 02:51 PM
waijai's Avatar
i.love.gold
Anodized lips shouldn't be polished.
Old Apr 20, 2005 | 04:15 PM
OvaYahead's Avatar
how do you get rid of fine lines on anodized finish?
Old Apr 20, 2005 | 04:23 PM
ColdFusion's Avatar
I've used Mothers Mag Polish on my Iforged wheels and it works great. It makes all those little hairline scratches less visible because of the shine it gives.
Old Apr 20, 2005 | 05:17 PM
waijai's Avatar
i.love.gold
Yeah I've used regular polish (red, blue, and pink Wenol) as well with good results, but it takes a lot of elbow grease. I was just looking at another alternative that I can try.
Old Apr 20, 2005 | 07:50 PM
G352NV's Avatar
Never enough
Moog if you want I can email you a how to I did on cycle frames. It would be the same as wheels.
Old Apr 20, 2005 | 07:54 PM
G352NV's Avatar
Never enough
Fug it heres the write up. If you have any questions just ask.
OK.
Polishing your bike can be easy if you follow the correct steps to make it simple for yourself.
I will detail the steps and equipment needed to polish your frame and swingarm.
I will also give you a list of materials needed to complete the job as well as a few places to purchase these items. Good luck with your project.
Materials Needed:
-You will need a buffer. I recommend a Sears/Craftsman 6in. Sander/Polisher model 91052.
This is a very inexpensive buffer. The buffing process can be rather harsh on a buffer so I don't recommend
using a $200 Porter Cable. The Sears buffer is only $50 and does the job very well.
-Spiral Sewn Buffs
-Loose Section Buff
-Emery Compound
-Tripoli Compound
-White Rouge
-Buff Rake
-Easy Off Heavy Duty Oven Cleaner
-Ear Plugs and Safety Glasses
-Mothers MAGS and Aluminum Wheel Polish
Here are the manufacturers, part numbers, and prices for the buffs and compounds.
The rest of the items can be purchased at various local stores.
The phone numbers can be found online at each of the manufacturers homepages.
Eastwood Products product parts# and prices:
Spiral Sewn Buffs 13034: $5.99
Loose Section Buff 13043: $5.99
Emery Compound 13134: $4.99
Tripoli Compound 13135: $4.99
White Rouge 13001: $5.99
Buff Rake 13120: $9.99
http://www.eastwoodco.com/
Caswell Products product parts# and prices:
Spiral Sewn Buffs SSCW65: $5.00
Loose Section Buff LCW65: $5.00
Emery Compound BLKBC7: $7.00
Tripoli Compound BRBC7: $7.00
White Rouge WBC7: $7.00
Buff Rake WR995: $9.95
http://www.caswellplating.com/
The Process:
We are now ready to get started on our polishing. The first thing we need to do is to remove any body panels that we do not want
to get broken, screwed up, or polished. I removed everything from my bike including the rear sub-frame. I did, however, leave the swingarm on the bike when I polished it. You can remove it if you like. I will not make a difference. The next thing that we need to do is to mask off everything that will not be removed from the bike. We do not want to get any over-spray onto the remaining
parts of the bike. I just used masking tape and newspaper. I suggest putting several layers of newspaper so that the oven cleaner does not soak through.
Now that our work area is clear, we are now ready to start stripping the anodized finish off of the work area. I highly recommend wearing safety glasses from here on. Start by spraying the oven cleaner on the work area. Try to spray close to the area as to
prevent over wetting your newspaper. Let the oven cleaner sit on there for about 20-30 minutes. Wipe off the oven cleaner with a wet sponge. Now reapply a coat of oven cleaner to the work area. Now the work area should start to turn black. Once it has turned black, you can wipe off the oven cleaner. Check to make sure that all of the work area is black. If there are spots, then you need to
reapply the oven cleaner to those areas to get the anodizing all of the way off. The areas that still have an anodized finish will not
polish. Now that our work area is free of any anodized finish, we are ready to start polishing.
Install a spiral sewn buff onto you buffer. I had to use two washers on the bottom of the buff to be able to crank the buff on really tight to the buffer. You will not want the buff to spin on the shaft of the buffer. I also recommend leaving the handle off of the
buffer as this will just get in your way.
We will start with the Emory compound first. This is a rather abrasive compound.
We will apply this to the buff. I recommend putting in earplugs now as the buffing process is quite loud. Turn the buffer on and lock it in at the fast speed.
Now take the Emory compound and apply it to the buff. By holding it against the surface of the buff, it will start to
melt onto the buff.
We can now start buffing. Hold the buff against the surface of the work area. Use a little pressure, but not too much as we want the buff and compound to do the work. You will start to see the black disappear from the work surface. You are actually starting to buff the work material now. You will begin to see results in no time at all.
I suggest moving back and forth in a slow even motion so you do not heat the metal too much and cause imperfections in the final look.
If you are leaving a residue of compound on the work area then you are using too much compound. Be sure to rake your buffs every few minutes to keep them clean. Once the buffs have filled with metal, they will buff very slowly and will be gray and hard. It is time to replace the buff at that time. Continue buffing all of the surfaces until they are smooth and appear polished. Even though the work area will appear polished, it will not be as appealing in the sunlight as it will if you finish the process.
The second step is very similar to the first step except for the compound. We will now need to switch to the Tripoli compound. This is a less abrasive compound as the first and this process should not take near as long. Follow the steps as before, once again letting the buff do the work. This will help to remove most of the scratches that the first step has left in the metal. Your work area should now really start to luster.
We are very close to finishing the project. The next step is to clean any of the compounds that may have built up from
the buffing process. I recommend using Mothers to clean this residue off. We do not want any residue built up that can scratch
the surface again. The last step is to remove all of the fine scratches from the work surface.
This process is the easiest, but the compound is the hardest to use. We will use the loose sewn buff and the White Rouge. The hard part is the fact that we are using a loose sewn buff so it is hard to get the compound onto the buff. Once it is on though, you will just lightly apply this to the work surface. This will remove any final scratches left by the first couple of steps. You will be able to keep your work looking nice by cleaning it with the Mothers.
This process does not have to be done all of the time.
The finish will be quite resilient once the polishing is done.
Old Apr 21, 2005 | 12:49 AM
waijai's Avatar
i.love.gold
wow thanks G352NV...that's quite a bit of work (that I might actually have to try) My wheel lips better magnify light and burn people's retinas out after all that work.
Old Apr 21, 2005 | 10:07 AM
OvaYahead's Avatar
g352nv -- are those polish directions from gixxer.com?
I think I used the same one to do my bike. I ended up sanding by hand from 200 up to 500 then some tripoli, and white rouge. Then ended up finishing with the metal polish they have at car and bike shows.
Old Apr 21, 2005 | 05:54 PM
damen's Avatar
the wheels can be polished with a drill just don't scratch the centers. i did mine by hand. i used mothers also.
this is why i went with chrome lips. i went through all of this polishing with my first set of wheels. i'll do chrome lips from here on out.
Old Apr 22, 2005 | 02:17 AM
G352NV's Avatar
Never enough
Well they are one gixxer but I did the write up on my local board. Someone posted them on there. I also posted them on tlplanet
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
