Tires Questions???
Old Apr 24, 2005 | 12:52 PM
Brian-g35's Avatar
Tires Questions???
Going to purchase tires soon, was wondering stock size are 225-45-18 and back are 245-45-18... Could i use 245-45-18 on all four tires? anybody done this before? And how much is your new tires you purchase? and brand? thanks
Old Apr 24, 2005 | 01:00 PM
GoSooners's Avatar
Your handling will be better...it'll be neutral because you'll decrease understeer but you might get the SLIP light on more often because the VDC system requres a ~1" height difference between front and rear.
Old Apr 24, 2005 | 05:59 PM
kenchan's Avatar
If you're worried about price, get the Yokohama AVS ES100's in stock size.
Then get some stillen swaybars and set front soft, rear med and your
car will handle very neutral.
Old Apr 24, 2005 | 06:20 PM
lowrider's Avatar
To reduce the understeer, maintain the stagger, and keep the electronics happy put 245/40/18 in front and 245/45/18 or 255/45/18 in the rear. The car will be more neutral, but I don't know if that's what you want or not. The electronics expect the stagger to keep you out of trouble, I would not upset that and put the same size tire front and rear.
Lou
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
