275/30/19 on rears?
Old Apr 25, 2005 | 07:12 AM
Rookie84's Avatar
275/30/19 on rears?
Is it ok to have 275/30/19 tires on rear wheels and 245/35/19 tires on front? The reason I'm asking is that a lot of 350Z owners run this setup, and I might purchase a set of wheels which have these very same size tires. 275/35/19 would be ideal, but I don't want to change rear tires if they have good amount of tread left. Would it mess up VDC and/or ABS? Thanks in advance.
Old Apr 25, 2005 | 01:44 PM
jdbinspired's Avatar
That's the exact setup I'm running on my G right now with 9.5(245/35/19) in the front and 10.5(275/30/19) in the rear... Never had any problems with the VDC acting up... Reason for going with setup up was because I have my G slammed and I didn't want to have any rubbing issues... take a look...
Attached Thumbnails 275/30/19 on rears?-g2.jpg   275/30/19 on rears?-g6.jpg
Old Apr 25, 2005 | 02:35 PM
IS300TOG35's Avatar
► Matt ◄
Is your front tire thicker looking than your rear tire? What is the width of both of your rims? I have a 19x8 and 19x10 and was thinking if I went 245/35 and 275/30 then my rears are going to look thin and stretched and the front will look thick and bulky. What do ya think?
Old Apr 25, 2005 | 04:57 PM
beangrower's Avatar
I'm pretty sure he said 9.5 in the front and 10.5 in the rear.
Old Apr 25, 2005 | 06:01 PM
kokoro's Avatar
running 19x8.5fr-245/35/19 and 19x 9.5r-275/30/19 and they work just fine. if anything i'll run a 235/35/19 on my next set just to thin out the fronts to match the rears.
Old Apr 25, 2005 | 10:09 PM
Seattle-CPV35's Avatar
I had the exact set up and it worked fine, however, depends on the style of your rim, rear tire may look too narrow... as someone pointed out on my pix. I replaced the rear with 285/35-19 since then and I am happy with the 285 set up since my VDC does not kick in as often as it did with 275/30 set up. Different tire manufacture may give some variances on tire width..correct me if I'm wrong.
I don't have updated pix but you can check how it looked with 275/30 set up in the gallery.
search for IP kenstyle...
Old Apr 25, 2005 | 10:16 PM
GoldSport's Avatar
Would there be any perfomance issues with having 275/30/19 tires on rear wheels and 245/35/19 tires on front with 19 inch rims? Would I also need to purchase new springs to make my car look better? One more thing, how much better will my handling be going from my stock setup which is 215/55/17 to the new setup? Let me know, thanks.
-GoldSport
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
mryogi
Aug 14, 2015 07:58 PM
