Need help on SEDAN offset.
Old Apr 25, 2005 | 04:29 PM
Ts916G35's Avatar
Cool Need help on SEDAN offset.
need help.
I am looking to geta set of AXIS HIRO or Supermesh for my 04 DG sedan.
The shop said i would have to go with 19x8.5 all around with 45 offset
and 235/35/19 tires all around. is that true?
are those going to work on the sedan and look good?anyone out there with 19x8.5 and +45 all around setup. if so, please post some pic.
can we get the staggered setup for Sedan? if so, what's the best offset for front and rear, also, what's the best tire size to get for front and rear.
thanks for help.
Old Apr 25, 2005 | 07:48 PM
Chico's Avatar
yes that will work. If you want staggered you need to go with 19x8.5 + 35 front and 19x9.5 +45 rear, 245/35/19 and 275/30/19 respectively.
That will give you a nice flush look. I own the Axis Milano with 20x8.5 +35, 245/35/20 all around and it fits perfect.
Old Apr 25, 2005 | 08:52 PM
THX723's Avatar
G Kreuzer
8.5" at +45 offset will work nicely for your sedan at stock ride height.
It will however not look its best (subject to oppinion) at lower ride height, due to the associated increase in negative camber (tuck in). One could always resort to using wheel spacers to bring them back out.
A more ideal offset for a lowered sedan would be +38 for the 8.5" wide wheels.
With respect to tire size ... 245/35-19 is a much better choice.
Old Apr 25, 2005 | 10:23 PM
Ts916G35's Avatar
my sedan is lowered about 2 inch. i am about half finger gap on my stock 17s.
so, what 's the best tires size i should get?
thanks...
Old Apr 25, 2005 | 10:35 PM
THX723's Avatar
G Kreuzer
... in that case, definitely go lower offset than +45.
At approx. -2" ride height and looking to use the 19" x 8.5" wide wheels all around, I would recommend the followings:
1. +38 wheel offets
2. 245/35-19 Tires
They will fit/look very nicely!
Old Apr 25, 2005 | 11:46 PM
hksjza70's Avatar
19x9.5 +42
19x8.5 +38
245(f) + 275(r)
Old Apr 26, 2005 | 12:56 AM
Ts916G35's Avatar
so, i should get 245/35-19 all around with 19x8.5?
with +38 offset?
what's the different between +38 and +45?
thanks
Old Apr 26, 2005 | 01:00 AM
Ts916G35's Avatar
how about 19x8.5 front and +38
and 19x9.5 and +38
with 225/40/19 and 255/35/19 tires.
that's my other option i got today from other shop.
Old Apr 26, 2005 | 01:15 AM
THX723's Avatar
G Kreuzer
Yes 245/35-19 is a more ideal size tire to use.
with +35 offset?
No ... please read my previous post. Use +38 offset.
thanks
The difference is 7mm of displacement.
and 19x9.5 and +38
Ahh Yiah Yiah ... make up your mind! Do you want 19x8.5" all around or not?
If you're looking to run 9.5" rear ... then you'll want +50 offset and that's tough to come by. You can go with somwthing as low as +42 offset, but that'll require a either fender clip/roll and/or dial in more negative camber so rubbing is not an issue.
Old Apr 26, 2005 | 06:06 AM
skeleton_cru's Avatar
Sedan
If you go with 8.5" all around then you'll want a +38mm offset or a little bigger (+40mm). The advantage here is you'll be able to roatate your tires.
If you go with the staggered set-up, you'll want 8.5"/+38mm front, 9.5"/+45mm.
With the 8.5" wheel consider a 245/40/19 tire.
Old Apr 26, 2005 | 07:50 AM
thoraxe's Avatar
There is a wheel fitment chart for the G35 sedan that someone made. It is awesome. I think it's on g-owners.com or you can google for it. You'll find it.
I have it and can email it but the attachment is too big for the forum. email me @ erik.jacobs@dgtrials.com and I'll send it to whomever wants.
Old Apr 26, 2005 | 09:40 AM
thoraxe's Avatar
I uploaded the chart here:
http://www.DGTrials.com/g35wheels
There's also an old video of me drifting my sedan. This was pre-figuring out how to remove the VDC fuse, so ABS was active. The first half of the first run I didn't have the traction control off, either.
It's funny because you can totally see the ABS screw me over when I tap the brakes to extend the drift. The car just stops. Oh well!
Old Apr 26, 2005 | 12:09 PM
Ts916G35's Avatar
yeah...
i decide to go with +38 wheel offets
245/35-19 Tires.
any suggestion on the wheels for 04 DG sedan?
anyone?
^^thanks
Old Apr 26, 2005 | 12:13 PM
THX723's Avatar
G Kreuzer
LMAO! ... look at the top of the chart where it says 'by xxxx'.
Old Apr 26, 2005 | 12:15 PM
Ts916G35's Avatar
is the bigger offset mean the wheels will come out more than the smaller offset wheels?
