speed bleeders
Old Apr 25, 2005 | 07:37 PM
jonathang35's Avatar
speed bleeders
Anyone have speed bleeders? Where did you get them from? how much $?
Old Apr 25, 2005 | 07:49 PM
G35fromPA's Avatar
Um...have you tried www.speedbleeder.com? As good a place as any!
The Brembos come with them stock from the factory.
Old Apr 25, 2005 | 08:08 PM
hey, i have brembos. Thats good to know. Thanks.
j
Old Apr 25, 2005 | 08:38 PM
THX723's Avatar
G Kreuzer
I'm curious where you got this information from? This is news to me.
Old Apr 25, 2005 | 08:39 PM
dklau33's Avatar
I just got a set but haven't installed them yet. I got the stainless steel version. I'll report back when I've installed them and used them for bleeding and give my impressions.
Old Apr 25, 2005 | 08:40 PM
do you have brembos?
Old Apr 25, 2005 | 09:03 PM
THX723's Avatar
G Kreuzer
Neither of us (myself and dklau33) have Brembo.
Old Apr 26, 2005 | 01:38 AM
dklau33's Avatar
Yeah, me too. I know it is real easy to change brake pads on the Brembos but I never heard of OEM speed bleeders. I'm sure some coupe person can speak up on this.
Old Apr 26, 2005 | 02:01 AM
THX723's Avatar
G Kreuzer
I highly doubt that is standard affair for the Brembo. I never saw any reference to it in the factory service manual. In addition, I'm about 99.9% sure Speedbleers's got a patent on their design.
Old Apr 26, 2005 | 03:58 PM
G35fromPA's Avatar
It's not made by Speedbleeder, but it is a one-way valve bleeder. It's very easy to get around patents, by the way, by slightly altering the design, so that's not really a showstopper. And, that kind of thing doesn't usually get referenced in a Nissan FSM. Both FSM's I've had for my Nissans had very little detail under the brake bleeding procedure. That being said, others on FreshAlloy have confirmed the presence of Speedbleeder type nipples on the Brembos. See this thread for more info:
http://forums.freshalloy.com/ubbthre...rt=&PHPSESSID=
"1) I think you (or someone) mentioned a while back that the G35 comes with its own version of Speedbleeders on the Brembo calipers. Can you (or anyone) confirm whether this is true?
Yes, they do....The bleeders on the Brembos aren't quite as handy as those you can buy aftermarket, but they also don't have the issue of being over-torqued and breaking or getting pushed too far in or out! "
Old Apr 26, 2005 | 04:07 PM
G35fromPA's Avatar
I think you will be quite pleased with them. I used them on my 92 300ZX, and they worked great and made bleeding a relatively quick and painless affair. Two nitpicks, however:
1) The threads for the speedbleeder are metric to fit the caliper, however the nut to tighten/loosen it is in standard sizes. So you'll need a standard wrench as well.
2) If you over-tighten them, they can break quite easily, potentially requiring you to drill out the broken threads and re-tap the caliper. The stainless version shouldn't have this problem, however.
Old Apr 26, 2005 | 05:03 PM
THX723's Avatar
G Kreuzer
Yes, I agree it's easy to get around patents. However, if the one-way valve was employed in this Brembo caliper, why was it not use in any other Brembo brake systems? It's entirely possible they started to include such a system, but I honestly have not heard anything about this among fellow tracksters and friends in the industry.
BTW ... I did read through the link you provided above ... it offered no solid information or evidence of the built-in 'one way valve' other than someone allege it comes with them.
Old Apr 26, 2005 | 06:36 PM
G35fromPA's Avatar
I can't speak to why Brembo would not include them in other systems, but it's not just "someone alleging" that they come with them. Riffster is the moderator for FA's G35 section, and an avid HPDE driver. He has upgraded much of his braking system, including retro-fitting the Brembos to his 5AT, and bleeds fluid regularly for track days. I'd say he ought to know as well as anyone. I guess someone could call up a dealership and ask, but I don't honestly believe they'll know the answer either!
Old Apr 26, 2005 | 07:03 PM
THX723's Avatar
G Kreuzer
I was hoping to not have to bring up names. But, yes, I know Riffster. We talk lots on FA among the many track event threads. I've PM'd him about this ... will share what he knows or doesn't know as I find out.
You're right the dealers won't know about this ... as they are w. many many other things. The same Brembo system used in the Z/G is also the same ones used in other production cars ... none have reported such check valves exists. It is highly unlikely Nissan had custom fitted them. But I suppose nothing is impossible.
Old Apr 26, 2005 | 07:17 PM
G35fromPA's Avatar
Thanks Clint. Let us know what you find out.
