Offset for Sedan Rims
Old Apr 30, 2005 | 03:03 PM
bert039's Avatar
Sorry I tried doing a search already but I couldn't find the answer I was looking for...
I realize that the perfect offset for sedans is +38 with 19x8.5 rims, but the closest offset for the rims I want are +35.
How much is this difference going to effect the way they look on my car? I know its a small difference but will I need to roll my fenders with a ~1.5" drop?
If I went staggered the rims in the rear would be 19x9.5, the offset in the rear is only offered with +42. Again that's only a difference of 3 (ideal being +45).
Bottom line, should I look into other rims? Or do you think they'll look and be suitable?
Thanks for the help!
Old Apr 30, 2005 | 08:20 PM
Chico's Avatar
You will be ok with that set up. You won't need to roll the fenders at all.
Old May 1, 2005 | 02:01 AM
Ts916G35's Avatar
so the 8.5" + 38 front and 9.5"+45 rear dont' need to roll fender at all on a lowered sedan?
Old May 1, 2005 | 08:58 AM
bert039's Avatar
excellent, thats what i was hoping for, hopefully it won't stick too far out from the fender
thanks for the help man
Old May 1, 2005 | 11:40 AM
Gsedan35's Avatar
To add,
Even with 275 tire's mounted on the rear. 245 max in the front is a given.
Old May 1, 2005 | 07:24 PM
Ts916G35's Avatar
the 8.5" + 35~38 front and 9.5"+42~45 rear
and 245/35 front tires. 275/35 rear is the bestset up for lowered sedan?
Old May 2, 2005 | 06:55 AM
skeleton_cru's Avatar
Sedan
Be careful with the +35mm offset. You may rub unless you run negative camber.
The 8.5/+38, 9.5/+45 is a proven combination. Also consider a 40 series tire. They will give you a bit more sidewall and a little more cushion. I am running 8.5/+38 with 245/40/19 tires on all four corners and I think it's perfect. I chose the 40 series tires because they had the closest overall diameter to the stock 17's.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
multimut
Canada
Jul 26, 2015 08:43 PM
