Tokico d spec for Coupe
Old May 1, 2005 | 11:31 AM
SCoupe's Avatar
Does anyone here know if installing the Tokico d-specs for the Z will lower the coupe more than d-specs made for the G ?
Old May 1, 2005 | 11:38 AM
Gsedan35's Avatar
The G and Z Tokico's differ in that on the Z application the Tokico's have shorter rear shocks. Remember the rear springs on these cars are not located on the shocks. So it's impossible for the rear shocks to effect ride height. In any event just to say it, you can have shorter shocks in the front and that will not change ride height, spring mount height will not change. Not to be confused with Koni's which do have removeable front spring perches and feature two different position's for the front spring perch.
Old May 1, 2005 | 09:57 PM
SCoupe's Avatar
[QUOTE=Gsedan35]The G and Z Tokico's differ in that on the Z application the Tokico's have shorter rear shocks. Remember the rear springs on these cars are not located on the shocks. So it's impossible for the rear shocks to effect ride height. In any event just to say it, you can have shorter shocks in the front and that will not change ride height, spring mount height will not change.QUOTE]
Thanks. To clarify - for myself - d spec for z or g won't matter eventhough z shock is slightly shorter. Height will be regulated by effect springs have ! ?
Old May 1, 2005 | 10:49 PM
Gsedan35's Avatar
Correct.
Will you be using these with lowering springs now or in the future?
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
BasquiatPicasso
Jul 23, 2015 06:26 PM
